windows or sunroof or mirrors not working
Old 07-06-2010, 10:49 PM
sickvehicle's Avatar
Default windows or sunroof or mirrors not working
well i dont know guys it was like this when i got it (1995 p38 model)
however when i shift in to reverse mirrors move down towards the street and back when in drive i checked the driver door motor jumped it and it does work i have some what checked the switch pack best i could and it seems to be getting power to the board on the dash it says rear windows off? had not notice that before until today it normally says not set and pointers before i take it to the dealer to raped..
Old 07-06-2010, 11:09 PM
RROJ's Avatar
Fuses?
Old 07-06-2010, 11:16 PM
LRScott's Avatar
Rear windows off means you have the rear windows switched off by pushing the switch to the disabled position (lower middle switch under the sunroof switch). If you've tried to re-engage them and the message won't go away, it is most likely a problem with the switch pack which is a fairly common problem.
Old 07-07-2010, 09:21 AM
Default fuses
Originally Posted by RROJ
Fuses?
checked all them
Old 07-07-2010, 09:28 AM
Default switch pack
you think it could possibly be the becm? i read a post where it could be that im planing on checking that..aswell as my cig lighter dont work ither also. tho i have not checked the connections behind it i just kno that the window switch and the cig lighter are on the same becm connector port i think its c625 or c626
i dont know worth a check
Old 07-07-2010, 01:31 PM
handsome rob's Avatar
Check the connections first underneath to make sure it is all there and attached. I doubt the becm is causing this but I may be wrong.
Old 07-07-2010, 08:02 PM
LRScott's Avatar
Start with the switch pack since its the cheapest and easiest to repair/replace. I would only look into the BECM if there are other random electrical problems not related to the windows.
Old 07-08-2010, 06:42 AM
i'll start with the pack i really started doubting the becm because im not having no other electric problems really gas door button dont work and like i said before the cig lighter does not work ither but i dont think its related?
Old 07-16-2010, 03:25 AM
Default fixed it
it was the switch pack thanxs lrscott and everybody else who chimed in...
Old 07-16-2010, 03:44 PM
skyguy's Avatar
was it water damage to the board under the swiches?
JERMAINE
10-05-2010 08:51 PM
Nick C.
02-26-2007 05:54 PM
sickrangerover
02-11-2007 11:44 AM
GPWHLS
01-10-2007 12:17 PM
Quick Reply: windows or sunroof or mirrors not working
