ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
CB Radios....Watcha Got???
Old Mar 31, 2011 | 03:03 PM
yloDiscoII's Avatar
Default CB Radios....Watcha Got???
What CB radio and antenna do you have? How/Where do you have them mounted? Pics are great!
I am currently shopping for a relatively inexpensive radio setup for basic trail comm and need some help. Thanks guys!
(oops for got an "H" in my title)
Old Mar 31, 2011 | 03:31 PM
hilltoppersx's Avatar
i got the cheapest setup evarrrr. the $40 Uniden special
Amazon.com: Uniden PRO510XL 40-Channel CB Radio: Electronics
and a K-30 magnet mount.
Amazon.com: Cb Radio K30 35 Inch Magnet Mount Antenna: Electronics
the uniden is mounted on my dash just right of the speedo console
the antenna is currently at the front of my roof rack. eventually im going to move to a rear bumper mounted antenna.
Old Mar 31, 2011 | 04:02 PM
yloDiscoII's Avatar
How does it work on the trail?
I borrowed a Midland hand held on my last outing and I couldn't transmit and i could only hear a few of the rigs.
Old Mar 31, 2011 | 06:58 PM
it works great! Its got good range I talk to truckers all the time. Dead simple, cheap and works well. I have seen people mount up where the sunroof switches are or behind the center console in the rear foot well. Ill take pic of mine tomorrow
Old Apr 1, 2011 | 12:53 PM
souljad9's Avatar
I'm in the middle of mounting mine where the sunroof switches are. I had to run new wires to the cb anyway. I had previously used fusetaps under the dash, but got so much rf interference, I had to turn the squelch up so high I couldn't hear people more than a few hundred yards away. I also added a spring to the antenna to get it up a little higher, as it was only about 6" above the roof line previously. It's mounted on the spare tire carrier.
Ed, If you don't mind looking at it, since your truck isn't your DD, you can mount it to one of the top tabs on your ARB. gives a much better ground plane than the rear tire.
Old Apr 1, 2011 | 01:20 PM
i dont have a rear tire it's in my truck now. yeah i have thought about putting it on the ARB. I am not sure yet. my k-30 is on my roof and it works great right now i have to wire my CB into the fuse box still. right now im just using a cigarette adapter and i get interference if i pull the windshield washer fluid. but since both my nozzles are broken i wont be using windshield washer fluid anytime soon so it doesnt matter.
Old Apr 1, 2011 | 05:24 PM
yloDiscoII's Avatar
Well I went ahead picked up a Midland 1001Z today for $30 at a Pilot Truck Stop. Now just need to choose a good antenna and find a good place to mount it.
Old Apr 1, 2011 | 07:05 PM
as high as you can! i use the whip so when it bangs trees and underpasses it just bends out of the way.
Old Apr 1, 2011 | 09:31 PM
Dezert Rover's Avatar
Yaesu makes a GREAT radio. very strong and will last forever..... even in the AZ heat
Old Apr 3, 2011 | 10:45 PM
Camdisco24's Avatar
I have a cheap cobra ultra and I have a ??" stainless steel antenna. Cheap set-up that has worked great so far. When I get a new bumper, I will prob change the antenna to something that doesn't whip around so much. Here are some pics... I painted the silver mount black so it blended in more.
Big Jim Swade
Apr 18, 2013 07:49 AM
hilltoppersx
Sep 13, 2010 08:32 PM
AK Rover
May 5, 2009 05:43 PM
Chrisinhouston
Jan 16, 2009 09:31 AM
sna77
Jul 11, 2007 05:00 PM
