ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
Ugly Duckling Update
Old Jul 7, 2010 | 10:04 PM
AK Rover's Avatar
Default Ugly Duckling Update
Since I finally managed to get the Ugly Duckling I've been working on it a little at time. Spent about a day and a half just going through the parts and other junk inside to see what I have, what's missing and what doesn't even go to this vehicle. I pulled the inspection cover off the transfer case to find no noticeable wear on the gears. I was pretty stoked about that. Today I disassembled one of the swivel ***** thinking it best to inspect the swivel ball and bearings. So far everything I have tinkered with has proven to be in remarkably good shape. It's quite obvious that the engine was the reason this particular vehicle was removed from service, and the engine is going to be replaced.
Old Jul 8, 2010 | 03:23 AM
jeffrudy's Avatar
awesome nice to see your starting to work on the beast.
i take it your folks caved in on the storage? post some more pics with progress
Old Jul 8, 2010 | 08:23 PM
AK Rover's Avatar
I haven't really done anything worthy of pictures yet. I keep working on it a little at a time as I find little bits of motivation. So far aside from a little cleaning I've only pulled the one hub/swivel ball assembly. It was kind of interesting to see the swivel ball disassembled but I still don't fully grasp how the axle shaft goes in. The rear is easy but the front has the u-joint for the steering that has me stumped.
It took a lot of negotiating but I got the approval to bring ugly duckling to the house. Once all my parts get here and it's at least running it won't be so bad. It will still be ugly for a while but at least it will be drivable ugly duckling.
Old Jul 9, 2010 | 05:12 AM
jeffrudy's Avatar
most people will look cross eyed at you when you say swivel ball ahaha even some mechanics....
pick up a shop manual and get to getting!
make a slideshow of B.A Series rovers that should give you some good motivation
Old Jul 14, 2010 | 08:52 AM
AK Rover's Avatar
Red hood with tire carrier. That is the brake pedal assembly sitting on the wing.
Finally cleaned the leaves and dirt out of the cargo area. Now just need to sort through remaining parts sitting on the sides.
Inside the t-case. Looks pretty good for 50 year olds. I hope the same can be said of me when I hit 50.
Passenger side half-shaft and swivel ball
Anyone think this is a problem?
Snafu / Disco Fries
Dec 7, 2022 07:46 AM
Jordanpryce
Nov 8, 2011 09:53 AM
mattrickman
Jan 17, 2011 01:54 PM
Street Wolf
Sights N Sounds
Nov 28, 2008 09:22 PM
cek
Oct 29, 2007 09:33 PM
