Installing a Temp Gauge on a 2003 Disco II
Old Sep 2, 2010 | 09:21 AM
vandev's Avatar
Default incredible
That engine is incredibly clean....whow....
Old Sep 2, 2010 | 09:25 AM
lipadj46's Avatar
Don't the gauges have a wire that you can connect to the headlight switch that will dim them when you turn on the headlights?
Old Sep 2, 2010 | 09:38 AM
agthird's Avatar
so how hot does the engine run?
Old Sep 2, 2010 | 12:59 PM
tito5590805's Avatar
180-185 normal driving (city and highway)
185-190 normal driving with AC blowing. (city and highway)
Old Sep 2, 2010 | 08:18 PM
DiscoWest's Avatar
Nice write up, beautiful engine bay!
Old Sep 4, 2010 | 11:10 AM
bosshogt's Avatar
Default engine temp
I would say the normal observed engine temp is:
  • 188F no A/C highway (outside temp below 80)
  • 195F - 205F with A/C in the city above 80 degree outside.
  • 1 bottle of water wetter. coolant change with the last 3 months
  • Everyone should check to see that their AC condenser fan is running. It will make you Rover run up to 10 degrees hotter with it broken.
These are what I have observed with the live digital readout from the ScanGuageII
Old Sep 4, 2010 | 11:18 AM
ROVERTECH15's Avatar
nice write up bro the only thing i would to is put some black wire loom on those green wires in the engine bay it will protect it from the heat and look alot better.those are some sweet guages tho and u did a very clean job installing!
Old Sep 6, 2010 | 09:46 PM
ShortTom's Avatar
Tito, GOTTA ask, did you buy your Disco that clean or disassemble everything and put each component through a hot bath?
Very nicely done, though I'd prefer a less intrusive (i.e. no holes) pillar set...I'm not sure the value of adding an aftermarket temp gauge though? I figure the factory one is accurate enough even though I don't know the exact temp.
Old Sep 7, 2010 | 08:41 AM
Bundu's Avatar
Banned
The factory one is crap, it shows cold, hot and replace engine. There has been enough posted about the heat gauge and how **** it is.
Old Sep 7, 2010 | 09:09 AM
My Disco was pretty clean from when I purchased it. I got it from a private owner and was very well taken care of. Before him, it was a lease vehicle and dealer maintained. Another positive is that it has lived in LA most of its life from around 3K to now at 57K. Originally came from Virginia. Carfax checked out nicely too. The only thing that I did was add some engine shine about 1 month ago, it protects the plastics and provides a nice shine to the engine on all the parts!
