110S Led Standard to Premium Led swap Question
Old Oct 24, 2023 | 08:04 AM
stevemfr's Avatar
Originally Posted by LoudounPrime
@HMBodo08 did you find a solution to this? I have the same problem. Also, I bought the IID GAP tool and it had no impact on the lights. No matter what setting I chose and uploaded nothing changed. Ugh.
Are you running the latest firmware on the IIDTool? Email Patrick support at gap-diagnostic dotcom
We're compiling a list of the required CCF edits for enabling the various options. Could still be a little while tho.
Old Nov 27, 2023 | 07:31 PM
dakluck's Avatar
Default This is the thread for me.
Just installed Premium LED lights on my 2020 L663 Defender S that came with the Basic LED lights.
Old Parts - L8B2 13W030-CF (L) & L8B2 13W029-CF (R) (For Sale)
New Parts - L8B2 13W030-FF (L) & L8B2 13W029-FF (R)
Upon initial install, the headlamps work, side DRL (squares) work, just no Halos.
I have a GAP IID so tried to scour the forums for a working combo.
Attempt 1
MultiCAN 679 HeadlightsVariant
  • Old - Headlamp_Variant_Low_C
  • New - Headlamp_Variant_Mid_C
No luck.
Attempt 2
MultiCAN-679 HeadlightsVariant
  • New - Headlamp_Variant_Mid+_C
No luck.
Attempt 3
Per https://www.defender2.net/forum/post1003577.html
MultiCAN-636 AdaptDrvBeam
  • Old - Disabled
  • New - Enabled
MultiCAN-706 Dyn Bending Light
  • Old - Not fitted
  • New - fitted
MultiCAN-693 ADB Initialisation
  • Old - Not fitted
  • New - fitted
No luck.
Attempt 4
MultiCAN-463 DRLBehWhilstDIsAct
  • Old - Turn Off
  • New - No Action
MultiCAN-465 DRLBehWhHazardsAct
  • Old - Turn Off
  • New - No Action
No luck.
Old Nov 30, 2023 | 05:03 PM
Pangea123's Avatar
I am also interested in the Eurospec ballast/ matrix light upgrade.
I emailed @markjlr from his website. Haven’t heard back yet but will update everyone if he can do the programming.
Old Dec 1, 2023 | 01:19 PM
dakluck's Avatar
If anyone can send me a CCF for a US spec L663 w/Premium headlamps that would help a huge help in determining the proper coding!
Old Dec 1, 2023 | 01:43 PM
Pangea123's Avatar
… kinda want to do it…
from mark JLR…
Old Dec 3, 2023 | 07:52 PM
DeadEndMike's Avatar
5th Gear
I found some on eBay. I asked them multiple times will these work on my 2020 S without me doing anything. They guraunteed they would
I installed them and so far no issues granted it’s been 48 hours. Idk which kind these even are. I’m just learning there’s multiple headlights. I thought it was just the basic ones and then these.
Old Dec 3, 2023 | 07:53 PM
dakluck's Avatar
Incredible! What are the part numbers?! Do you have IID?
Old Dec 3, 2023 | 08:07 PM
HMBodo08's Avatar
Post the seller link from eBay. I’m curious to see how these are. Are they OEM lights? Also does the adaptive high-beam work with them?
Old Dec 3, 2023 | 09:20 PM
5th Gear
https://www.ebay.com/itm/39428935071...mis&media=COPY
I have no idea if they are OEM
Old Dec 3, 2023 | 09:26 PM
5th Gear
ill have to check for part numbers.
Whats IID?
