12v switched power?
Old Apr 8, 2023 | 07:58 PM
tr182md's Avatar
Looking into doing the steering wheel pass through for the Antenna but also there is a wire on the Switch pro that needs to go through if you are doing that one instead of the Trigger. I have not purchased either so far but the Switch pro looked nicer to me. Any good reason to go with Trigger instead?
It would be nice to have a photo of that grommet. On the interior I imagine you remove the side part and then the lower panel? I thought I saw that there might also be a grommet near the brake?
Any photos of the actual grommets would be appreciated. I have the GMRS and want to run the switch Pro wire at the same time even though I don't have lights yet just to do it together. If it is super easy I could just get the Antenna working now.
Old Apr 14, 2023 | 01:12 PM
GCSchmidt's Avatar
I used the Lucky8 method of running my wires from the engine compartment to the interior. I used it for my Switch-Pros and GMRS installs.
https://cdn.shopify.com/s/files/1/21...f?v=1630502139
BritCars
Jan 4, 2020 09:45 AM
LR03NJ
Audio/Visual Electronics
May 6, 2010 04:40 AM
Disco_Fever
Jul 9, 2009 03:38 PM
gtagg
Nov 24, 2007 07:36 PM
03springer
Sep 27, 2007 12:43 PM
