20" Redbourne with 285/55/20 Nitto Recon Fit?
Hey guys, I looked through all the threads and it seems like 275/55/20 is the safe bet, but will a 285/55/20 fit on stock suspension without rubbing?
I have seen a few pictures of this setup and was told it does not rub, but from posts here I am not sure? I will have the wheel arch protection and no plans to change suspension in anyway.
Thanks for advice!
BK
Thanks for advice!
BK
Have you checked this thread (and likely the first posting that they update)? https://landroverforums.com/forum/20...ogress-101530/
Hopefully what you seek is in there. Go to the top of the forum and click "Search" and choose "Advanced" if you want to accelerate things. I don't know the specific answer, but I bet it's already in there. Good luck!
https://www.instagram.com/p/CSaSFhaM..._web_copy_link
This 90 has 20x9in wheels with offset of ET 30mm. He's running 33x11.5 Ridge Grapplers, which is pretty close to a 285x55-20 sized tire. He says there is "zero rubbing with this setup". I have a 90 on order and plan on running the same (or very similar setup)
For comparison, the Redbourne wheels are 20x8.5in and ET 25, so in theory, it should work, but I can't personally say for certain.
GrouseK9 (10-06-2021)
The lift is not the issue here, as it is the tyre that catches the wheel arch liner when on lock. My 275/55r20 on standard rims just catch the front mudflaps on lock whether the suspension is lifted or not.
