2020 defender x p400 engine failure
Old Jun 29, 2022 | 03:02 AM
jemzimbo's Avatar
Default 2020 defender x p400 engine failure
Hi, have any owners of the New Defender X P400 had an engine failure? Mine has just failed with cyclinder number 1 misfiring. After a diagnostic check at the dealers they said it has low compression and after carrying out a leakage test found cycliner 1 was losing compression into the crankcase. They have recommended an engine replace but not "offered" one under warranty yet????
Old Jun 29, 2022 | 07:21 AM
jemzimbo's Avatar
JLR local agents have just come back to me on the P400 saying they'll escalate the matter so replacement engine should be covered
Old Jun 29, 2022 | 08:22 AM
WTFChuck's Avatar
Well, that’s very generous and caring of them.
Old Jun 29, 2022 | 10:33 AM
nashvegas's Avatar
That sounds like a disappointing experience. How many miles/km on the vehicle? Are you in USA?
Old Jun 29, 2022 | 03:39 PM
CombatNinja's Avatar
Considering mine has been at the dealer for 10 days getting the windshield replaced (which was on hand), the PCV recall (again, parts in house) and a software update, I hope your Defender is good to go in 2024 when you pick it up from the dealer.
Old Jun 30, 2022 | 08:20 PM
Paradigm's Avatar
Oh come on, that is mean. He will have it back by end of 23 easy
Old Jul 4, 2022 | 04:32 AM
jemzimbo's Avatar
No, I am in Zimbabwe, Southern Africa. There have been two other engines fail locally and more in South Africa I believe. The worry is once its replaced with could take ages how are you guaranteed it will not happen again?
Old Jul 4, 2022 | 04:33 AM
jemzimbo's Avatar
Sorry the vehicle only has 15,000 kilometres or 9000 odd miles on it.
Old Jul 4, 2022 | 02:52 PM
NoGaBiker's Avatar
Sorry this has happened. But these things do happen. I had a 2014 Jeep Wrangler. It dropped a valve seat down into No. 6 cylinder and punched a hole in the side of the block, just shy of 15,000 miles/2 years. Jeep put a new long-block in (that’s everything below the cylinder head — not sure if the term is used outside the U.S.) and I sold it to a friend last year with 45,000 miles and he’s put another 15,000 or so and no further problems.
I don’t think catastrophic engine failure is a common problem on these trucks. Good luck!
Old Apr 16, 2023 | 07:59 PM
Tom Constant's Avatar
Default Issue with engine
Hello, I’m the owner of a Defender X-Dynamic p400 living in Ivory Coast. My engine had a failure with 2 cylinder (compression issue) after 6 month of ownership and 7 000 km. The engine has been replaced by the dealership, in the city of Abidjan, Ivory Coast nearly 50 Defender engine had broken, the dealership is fully aware and this situation and they have stopped the importation of the P400 6 Cylinder. They said the issue is related to the fuel quality, however all the other model of JLR don’t have this issue and we have tons of Range Rover here.
I also add the windshield issue, the roof top issue, and two of my main front light collapse at 2 month of interval.
