2021 defender coolant pipe leaking at head above exhaust manifold
Old Feb 17, 2025 | 06:01 PM
Furry9900's Avatar
Default 2021 defender coolant pipe leaking at head above exhaust manifold
2021 defender 110 p400 coolant leaking from a small pipe above the exhaust manifold. Looks to be an easy replacement but I can not identify the part # to order a pipe or o-ring kit. I have the tag from the part but can not seem to cross reference it to anything of use. Any help would be greatly appreciated. I can't really remove the pipe and go on a hunting mission all over town for the o-ring as the car is needed every day
Old Feb 17, 2025 | 06:33 PM
nashvegas's Avatar
Hmm. Good mystery. If it is what you have pictured there,...
I could not find it on any of the COOLING SYSTEM diagrams here --https://parts.jaguarlandroverclassic...nd/land-rover/. (P400, cooling system parts diagrams) But I’ll be darned if they didn’t put it here on the P400 CYLINDER HEAD diagram lol -- https://parts.jaguarlandroverclassic...nd/land-rover/
Hose is # LR121400
2 bolts that hold it on are LR073655
I cannot tell if it comes with the o-rings or not, but they are annoyingly *not* listed separately on the diagram. The o-ring (s) is technically inside the box for the hose so hopefully that means they are included?
Good luck !
Old Feb 17, 2025 | 06:37 PM
Furry9900's Avatar
Thank you. Now my question is what do the numbers on the tag mean?
Old Feb 17, 2025 | 06:45 PM
nashvegas's Avatar
That’s a great question. I don’t really know the answer. But....
The date is the only one that I think is of use. The rest - I think it’s all manufacturing nonsense. I have heard - anecdotally - it is internal production codes for build in the factories -- for just in time manufacturing processes. I’ve tried scanning those QR codes. Never works. I’ve also tried to attempt to match those letter-number codes to the LR part numbers. Nothing ever really comes up. Ie I havent cracked the code.
I browse parts online on ebay and lots of sellers seem to think that these codes are the LR part numbers, btw. Not the case. LR assigns a separate part number from those codes sometimes labelled on the actual part there.
Makes no sense to me really.
Sometimes I think how easy it would be as an owner/consumer to scan a part’s QR code when you need to replace it, get the JLR part #, and order it?
You would think that would be the case...
Old Oct 3, 2025 | 10:45 AM
iLikeWaffles's Avatar
5th Gear
I need to order the pipe as well. Do you ever figure out if you can just get the o-rings?
Old Oct 5, 2025 | 10:21 AM
crackhead's Avatar
how much coolant were you losing? I top my reservoir off every month-month/half..
Old Oct 5, 2025 | 10:43 AM
5th Gear
I top it off every week. I'd say about 4-6oz per week. I replaced the turbo coolant o-rings last month, but still smelled coolant, so found this leaking pipe too. Seems like the orings are all going around 80k miles. Anyway I ordered a new pipe, as the dealer said they don't sell the orings separately.
Old Oct 5, 2025 | 10:49 AM
crackhead's Avatar
Is that the difference between MIN and MAX? I don't see any coolant stains on the turbo side of the engine, just the intake side.
Old Oct 5, 2025 | 10:59 AM
5th Gear
yeah it pretty much gets to MIN every week. All my leaks were on the turbo side. I can upload a diagram of the intake side this evening so you can see what you're dealing with. There's quite a bit of hoses on that side. You can always pressure tester kit and see where it's leaking from. Something like this https://a.co/d/30FZNn3
Old Oct 6, 2025 | 07:44 AM
5th Gear
You're pretty much dealing with everything other than #1,2 and 3 if it's close to the intake...
Or the Charge air cooler, which sits on top and has 4 coolant lines...
