2022 Defender - Electrical Issue
Old Oct 9, 2021 | 07:00 PM
Newbote's Avatar
Default 2022 Defender - Electrical Issue
My ‘22 HSE left me stranded at Costco today. I went to start it after being in the store for a bit and I got the warning “Engine Temperature Indication Fault Detected”. To top it off the engine cooling fan started running and wouldn’t turn off until it completely drained the battery. Called LR roadside assistance who sent the wrong tow type of tow truck. So, after wasting 3 hours I told them I would go home and send another tow truck later tonight once the parking lot was empty. To top it off if the battery is dead you can only lock the drivers door - there is no way to lock the other 3 doors. Even had someone from the dealer come out to see if they could figure it out.
Has anyone got a warning message like that before? The adviser said it was likely a sensor and depending on which one it could be hard to get . The dealer only has limited loaner cars due to the car shortage - are they required to provide a loaner? My fear I could be without it for awhile and don’t want to have to be stuck paying for a rental.
Old Oct 9, 2021 | 08:29 PM
ElVerde's Avatar
Sorry to hear. Hopefully this can be solved easily.
Any dealer worth their salt would be paying for your rental, if that's what it comes to, in a case like this. I'd be extremely disappointed if they didn't.
Old Oct 9, 2021 | 09:15 PM
kpd122's Avatar
Sounds like a bad sensor fooling it into thinking it's overheating, hence the fan kicking on. Most newer cars will allow the fan to run with the vehicle off. If so. Should be an easy and quick fix if that's the case. Fingers crossed for you!
Johnnycat
Aug 7, 2025 03:19 AM
Varalith
Nov 11, 2022 12:17 PM
CO_Laser
Aug 26, 2021 09:53 AM
the007goose
Apr 12, 2021 11:42 AM
Mark M
Jan 27, 2021 06:43 PM
