22" All Terrain Tires that fit with Air Suspension
I have a D110 P400 with air suspension & 22” factory wheels. I’d like to put on some all-terrain tires that will work well in winter (more on-road than off-road). Has anyone fitted 22” Nitto Ridge Grapplers, and will these + 30mm spacers work with no rubbing?
Any recommendations on a better tire for winter that still has the look of the Grappler?
I have 22” factory wheels, and I changed to Nitto Terra Grapplers 285/45r22. They look much better than the stock Continentals but are slightly louder on the highway. No rubbing even on the lowest height setting.
As previously pointed out, 22” wheels/tires are really not good for off rode use. I have a set of factory 20” wheels with Goodyear all terrain tires that I swap on if I want to go off road.
There are actually all-terrains in the factory size available. I believe the Cooper Discoverer AT# and the Bridgestone Trail Terrain, both severe snow service rated. The Bridgestone is a bit of a newer tire so it probably has the latest and greatest tech. Either one would be better than the factory junk for snow.
285/45/22 is not an issue. adding those 30mm spacers will most likely rub with no lift. that will most likely push your net offset to around 10-12. wheels will sit flush with the fenders, fronts will poke a little and look great but expect to rub
offset of the wheels is the biggest cause of rubbing
a 1 to 1.5 inch lift should fox any rubbing issues
