4.0.0 - Radio Source Bug
Old Aug 10, 2023 | 05:36 AM
XplusYplusZ's Avatar
Default 4.0.0 - Radio Source Bug
I noticed a weird behavior as a result of the software upgrade in the radio stations:
BEFORE 4.0.0
I had 6 favourite DAB stations I could cycle backwards and forwards through using the left right arrows on the steering wheel. It could cycle alphabetically through the 6 stations, then return to the first again for a new rotation.
NOW with 4.0.0
It seems to cycle through my 6 favourite DAB channels, but then at the end of my favourites list it then changes source from DAB to FM channels, and weirdly starts adding new favourites in the FM channels.. It's bizarre, and frustrating.
Besides 4.0.0, I did also change my configurable "diamond" button to long-press = change media source. I don't know if that's triggered the issue, but whatever's happening, this is a bug, it's not supposed to do this on arrow presses.
Anyone have the same?
Old Aug 10, 2023 | 08:42 AM
pjeski's Avatar
Mine still works. (I’m on 4.0.1)
Old Aug 15, 2023 | 06:37 AM
I found a solution to my issue - by logging into a profile the cycling logic seemed to work correctly. If you try to cycle through stations without loggin into a profile, it seems to change from DAB to FM for some reason. Weird, but as long as you're logged in to a profile, it's fine.
huggi
Sep 9, 2016 11:21 PM
K9Hexe
Oct 3, 2014 09:06 AM
yorocky
May 17, 2014 04:55 AM
