75th Anniversary 110 Height with Expedition Rack
Old Jul 24, 2023 | 02:50 PM
ThisOldSong's Avatar
Default 75th Anniversary 110 Height with Expedition Rack
Good afternoon! I am new to the forum as I just purchased a 75th Anniversary 110. I saw quite a bit of questions regarding the height with the factory expedition rack. My office parking garage has a 6'8 (Six foot, eight inches) clearance for the entrance which I've confirmed to be measured exactly.
With the height set to access mode, there is around 1/8-inch clearance, maybe a bit more. In turn, the height is slightly under 6'8 (YMMV).
Hopefully, this helps some of you out!
Old Jul 24, 2023 | 03:41 PM
inater's Avatar
The center screen will show you the height and dimensions of your car at different ride heights. I think the rack is another 2 inch (I have front runner). But I just look at the screen and then measure the added height of the rack.
I have seen 110s in a 6'8 garage with a rack but its very close. I am not sure if they lower the car before going in as well.
Old Jul 24, 2023 | 03:57 PM
DoctorofRocks's Avatar
I always allow 7' for a safety margin. This rules out some parking structures (particularly at airports) but I know from experience that the listed heights are not always accurate and do no include things like illuminated signs, sprinkler heads, etc.
Even with never going into a garage signed at less than 7' I have picked up a couple of gouges on the rear of the expedition rack from some lower hanging points.
Old Jul 24, 2023 | 09:46 PM
is21447's Avatar
I have a 2022 110 with coils springs and an oem rack and it fits just fine on a standard height garage. We used to drive carefully going in but now we just drive in normally.
Old Jul 25, 2023 | 01:47 AM
nashvegas's Avatar
The expedition rack surely adds more than just 2", right? I have it on my 110 (for 1.5 years) and I swear it's more than 2". Perhaps I'm wrong but...
Old Jul 25, 2023 | 04:52 AM
Mike_F's Avatar
I have a 110 on coils, no roof rack. When I enter the Philadelphia Airport parking garage (posted height limit 6'2"), the antenna fin bumps the PVC pipe that hangs down to warn you you're too high. I stick to the spiral ramps and go all the way to the roof and park outside; I've never tried parking on one of the lower decks. I really don't want to have to let most of the air out of my tires just to back out of my parking space.
So... be careful.
Old Jul 25, 2023 | 07:22 AM
MickD's Avatar
I just measured my rack, it adds 4 1/4".
With suspension at normal height it's about 82" to the rack. With the suspension at access height it's 79 3/4". So as others have said, a 7' (84") garage is probably safe but I'd still drop it to access height for an extra margin of safety.
Old Jul 25, 2023 | 11:16 AM
uclafan818's Avatar
Haven’t measured myself, but the quoted height of the defender is to the top of the antenna. So it might only add 2 inches to the total height, despite sitting 4+ inches above the roof.
Old Jul 26, 2023 | 03:16 PM
GavinC's Avatar
It adds 53mm to the overall height of the Defender. The shark fin antennae is the high spot without rack.
Old Aug 14, 2025 | 08:48 AM
HardTopRod's Avatar
4th Gear
Hey Mick,
When you say the rack adds 4 1/4", is this the measurement from the top of the roof to the highest point on the Expedition Rack?
Or from the OEM rails to the top of the Expedition Rack?
