Aftermarket lockers and lift for defender 90?
The drivetrain technology of the New Defender does not lend itself to adding lockers post purchase. The differentials are clutched and apply directional force to the four corners of the vehicle progressively. The on/off locker is obsolete.
If you are going off-road, you need to purchase the off-road pack to include the electronic rear differential.
If you are getting the air-sprung 90, then the lifts on the market now will likely work. I see you mentioned the coil set up. If that is the case, I would assume at some point OME or ARB will likely have some type of suspension lift for the coil sprung defenders. To date, I don;t see any listed.
Rob
V8DEFENDER90EUROPE
Defender
01-14-2023 11:23 PM
