Aftermarket lockers and lift for defender 90?
Old Jan 10, 2021 | 05:37 PM
saltynarwhal's Avatar
Default Aftermarket lockers and lift for defender 90?
Is there a lift and or locker available for the new defender 90? I’ve thought about getting one with the coil suspension.
Old Jan 10, 2021 | 08:39 PM
SmokinV10's Avatar
Doubt it on the lockers. Surprised if the lift isn’t the same as the 110
Old Jan 11, 2021 | 06:19 AM
TrioLRowner's Avatar
The drivetrain technology of the New Defender does not lend itself to adding lockers post purchase. The differentials are clutched and apply directional force to the four corners of the vehicle progressively. The on/off locker is obsolete.
If you are going off-road, you need to purchase the off-road pack to include the electronic rear differential.
Old Jan 11, 2021 | 07:52 AM
crewcabrob's Avatar
If you are getting the air-sprung 90, then the lifts on the market now will likely work. I see you mentioned the coil set up. If that is the case, I would assume at some point OME or ARB will likely have some type of suspension lift for the coil sprung defenders. To date, I don;t see any listed.
Rob
V8DEFENDER90EUROPE
Defender
Jan 14, 2023 11:23 PM
honden-coach.nl
Defender
Nov 5, 2012 06:02 AM
roving patrol
Defender
Dec 10, 2011 11:39 PM
swenrac
Defender
Jun 19, 2010 07:06 AM
RoverNeil
Defender
Dec 25, 2007 02:49 PM
