Air Suspension in Dynamic Mode
Old Nov 30, 2023 | 11:34 AM
MattF's Avatar
Originally Posted by Racer20
Did you code your car via some aftermarket way to have dynamic mode from the V8 model? P300 and P400’s don’t have it unless you code it in, that’s what we’re talking about, not the S mode on the shifter. The steering and suspension do change when you select I-Dynamic from the UI mode selector.
Yes - It was activated along with other things such as ACC
Old Dec 2, 2023 | 07:27 PM
VillaDazzler's Avatar
Originally Posted by bridgestreet
just to make sure I’m understanding this correctly, you’ve lowered your standard height by 20mm using the GAP tool? have you found any issues with daily driving/activities? I wouldn’t think so but I imagine access height is now quite low. to the contrary, any improvement in handling?
Suspension is tighter, doesn't float in comfort mode. Even better in dynamic mode with the dampening. Access height has about 1" clearance to the flare guard fender on front tyres, much more everywhere else. Offroad height clearance is 260mm to the fitted rear diff guard which is my lowest point in centre channel. Most times I won't need more and can appreciate the extra travel especially when lifting and dropping a wheel. The ride is much better as well. Very easy to change heights with the tool if more clearance is required.
Old Dec 7, 2023 | 05:01 PM
lrFFM's Avatar
I drive the V8 and there is definitely a huge difference between "Comfort" and "Dynamic" mode.
It also should be noted that the V8 Defender has larger-diameter and more solid anti-roll bars in addition to the unique Electronic Active Rear Differential.
See the JLR press release: https://media.landrover.com/en-gb/ne...ons-join-range
Old Dec 8, 2023 | 11:54 AM
mrego's Avatar
At least in NA, any Defender P400 model can be fitted with Active Differential (mine has as an option), not only V8s. From everything I have read (way too much) I think the only difference in the V8 when compared to the P400 models is the engine and maybe brakes in some V8 options. The rest of the car (mechanically speaking) is (or at least can be configured) all the same.
Old Dec 8, 2023 | 02:51 PM
lrFFM's Avatar
It’s the same in Europe. Active differential can be fitted to the P400. But the V8 has a different differential and also different anti-roll bars. So there is a mechanical difference.
Old Dec 9, 2023 | 11:29 AM
lawnmowerhombre's Avatar
There are definitely a number of structural differences in the vehicles. They didnt have a choice because of the weight and power of the V8. Its why the roof load is zero. Its not a P400 with a different motor. The brakes on all V8s are different. The big Brembos are why you cant run anything below a 20 inch wheel.
Old Dec 19, 2023 | 07:39 PM
msgm1's Avatar
Originally Posted by brulz
Hi everybody,
On my P400e with Air Suspension, I have unlock the Dynamic Mode with Configurable Dynamic.
So... in the setting of the Dynamic-i I can select Engine, Steering, Gear Shift and Suspension.
If I can feel the difference switching ON/OFF the Engine, Steering and the Gear Shift (and I can understand how the mapping change the car feeling on throttle, gear shift and hardness Steering),
but I can't feel the difference in the Suspension....
The Defender as only air Suspension (witch can influence the hight) but and do not have the active shock absorbers!
By activated or deactivate the Suspension the hight on riding mode do not change... so... on what parameter the Suspension in Configurable Dynamic influence???
Anyone know it?
Maybe the pressure of the air in the suspension chamber?
This maybe can simulate a spring harder??
Thanks
Jacopo
How did you unlock this in your car?
Old Dec 21, 2023 | 02:52 AM
brulz's Avatar
4wd High
not exactly...
The V8 has the same Brembo brakes of the P400e... same diameter and same caliper..
The same is for the differential.. same part number..
The V8 roof load is "Zero" just because the max speed of the V8 is limited to 240km/h...
If you put 100kg on the roof the barycentre is move too high for 240km/h...
Old Dec 21, 2023 | 05:32 AM
sarek's Avatar
The dynamic mode settings are mainly noticed driving at speed. The steering has less power assist proportional to speed . At parking lot speed, it will feel the same as comfort. The transmission holds gears longer, however you have to be in S mode to put the dynamic mode in play. The suspension dampers are stiffer at speed while turning (less body roll), but it should not feel stiff if driving at slower speed. As noted above, the V8 does have thicker sway bars. I only notice the throttle response difference on the p400 and v8. My 22 p300 doesn't seem any different.
All new defenders if equipped with air suspension have active dampening shocks. There is no configuration that doesn't have the electronic dampening unless you have coils. The V8 doesn't have a different type of active rear differential other than the gear ratio is different, however JLR will program and configure the vehicle differently and making CCF changes will not always have the affect that a vehicle has that was equipped from the factory. Every year and model has changed that sometimes don't have any logical reason.
Simon Millar
Oct 9, 2023 01:57 PM
Miami Man
Jun 13, 2022 09:07 AM
WiL2508DaN
Nov 9, 2019 12:08 PM
WiL2508DaN
Sights N Sounds
