Is air suspension worth it if I don't plan to do much off roading?
Hello all,
I am in the middle of spec'ing my defender and am wondering what the advantages of the air suspension is if I'm not planning on off roading very much or even at all. Is the ride about the same with the coils or is it much better? I also read somewhere on here that due to supply chain issues you can't even get the air suspension right now, and if this is the case then I guess the decision has been made for me.
Thanks
Thanks
Hello all,
Thanks
Thanks
-The ability to lower the vehicle to allow easier access for disabled and elderly passengers, as well as provide increased clearance for entrance into low garages.
-When towing the rear air suspension will compensate for heavy tongue weights which would normally leave a coil sprung car sagging.
-Compensation for heavy passenger/cargo loads.
-Better ride in an empty or completely full vehicle.
-Generally better at reducing vibration transfer
As for supply issues- I wouldn't be concerned. We've had a pretty steady supply of air suspension components on the assembly line and as long as you opt for the towing package and air suspension package it should be prioritized.
Hope this helps!
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
In all seriousness, I love the air suspension.
Were you involved in an accident? It's extremely rare (borderline improbable) to hear that two air struts require replacement on a new Defender due to a defect.
Could you expand on the problem? I'm curious if the retailer has misdiagnosed the issue.
In my case there was a service bulletin for a small leak in the front springs on a specific production date Defender. This was for early builds and mine was a 2020 order. What signaled the issue was the truck lowering when left for an period of time
Not sure if this is the case for the OP
Yes, unfortunately the parts come by sea rather than air and shipments have been slow going out from suppliers, so six weeks sounds about right.
