Alarm thinks driver's rear door isnt closed
Have a weird scenario.
The Defender locks fully, but I get the double beep as if there is a door open, but also on the dashboard there is not indicators of an open door, until I actually open it. I will get the REMOTE app notification of "did you forget to lock your defender"? but the defender is fully locked when I check. Messing with some stuff on the settings I can see something that said "last issue: driver's rear door not closed"
Has anyone else had something similar? the latch fully closes, but might not be sending the right info to the alarm computer? because again, the dashboard doesnt say the door is open.
Greatly appreciate any insight
Mine just starting doing this as well the last few days. I have a 2022 p400. Just did a sota update a few days ago. Also the dogs set of the alarm while I popped into the post office. Problem seems to be ongoing since then.
