Anyone install the Octa rep spare on a regular defender?
Old May 17, 2026 | 07:53 PM
mammothcar1's Avatar
Default Anyone install the Octa rep spare on a regular defender?
For those of you have bought the Octa reproduction wheels for your regular defender, have any of you bought a 5th wheel to mount on your spare tire carrier?
I know that on the Octa, they redesigned the rear bumper with a cutout to accomodate the larger wheel and tire.
I also read somewheel the LR also beefed up the carrier and hinge on the door to account for the weight of the wheel and tire combo.
What is everyone doing for a spare if you're running the Octa reps?
Thank you
Old May 17, 2026 | 07:57 PM
Termite's Avatar
Had mine on for two years. Fit perfectly.
Old May 17, 2026 | 08:00 PM
So no need to modify the carrier for the spare and the tire clears the bumper?
Any photos you can share or message me?
Thanks!
Old May 17, 2026 | 08:51 PM
Termite's Avatar
Just took the wheels off of the truck. No mods at all and the wheel bolted right up to the spare tire carrier.
Old May 17, 2026 | 09:00 PM
Thank you, I appreciate the info.
btw, your truck looks fantastic, perfect build
Old May 17, 2026 | 09:27 PM
jwest's Avatar
Thanks!
The clearance will have almost nothing to do with a replica wheel vs octa vs standard Defender wheel aside from how the offset of any given wheel brings the tire toward the bumper.
The biggest factor is really just the tire itself. Too large and it's not going to mount. Simple as that.
Having looked at the the bumpers, I'd bet that anything larger than 32.5 -ish, won't bolt right on, and a 33", the octa spec, won't actually fit, or if it does, it will be contact and a snug push to make it work.
This is why there are the spare tire mount offset plates like sold by lucky8 and other places. Really any modern rover adapter will work as there is nothing Defender specific to the Defender about the stud geometry or threading. A plate made for a Disco ii or lr3/4 ought to work fine.
Just keep in mind that replica wheels, are almost always a wider ET (offset) in order to "look cool". This will help in the fit. However, a factory octa wheel will sit closer to the mount and therefor close the remaining gap which will then depend more on the tire size you choose.
A normal defender spec tire shape ought to fit fine with either wheel though because they do leave a little room to spare.
Even on the OCTA bumper, going to 35" is probably the max, and will also probably touch if too wide a tire choice. Mine has a 34" but it is as narrow as there is at 275/65-20, so I have about 1/2" remaining clearance, maybe slightly less.
Lastly, not all tires are the actual same measurements. This is a Nokian Outpost NAT 275/65-20. Now that I'm seeing the photo again, a 35" would more likely require the mount adapter to shift the tire out and up. Then a 37 might work LOL.
Old May 18, 2026 | 07:51 AM
Great info and thanks for the photo, very helpful
Darover2
Sep 9, 2025 03:01 PM
adi
Sep 13, 2023 05:27 AM
SYD110
Jun 27, 2023 12:59 PM
