Attachments that fit roof rail or utility side rail?
Old May 29, 2023 | 10:09 AM
Mike_F's Avatar
Default Attachments that fit roof rail or utility side rail?
I have a 110S (coil springs), with roof rails but no roof rack. I have a set of crossbars I'll attach occasionally when I need to put a Thule box on top, but I leave them off most of the time because the vehicle is already too tall for some parking garages, and I need to park at the airport a couple of times a month.
But... I have a few things which I might want to attach to the outside of the vehicle when off-roading. One is a shovel.
There are various paddle/shovel holders (rings, basically) that can attach to roof racks. Here's an example:
https://yakima.com/products/topgrip?...567.1685372226
Has anyone found a way to attach something like that directly to the roof rails? Is there an insert that can go into the rails that the rings/attachments can bolt into? I was thinking some something like PowerfulUK's "roof rail eyelet kit" (https://www.powerfuluk.com/vehicles/...nder-l663.html). Can the inserts from that kit be used to attach paddle/shovel rings (or any other kind of Thule/Yakima attachment)? I realize there might be a 90-degree problem (roof rack rails run perpendicular to the line of travel; the roof rails themselves run parallel).
Alternatively, has anyone installed the PowerfulUK "utility side rail" (https://www.powerfuluk.com/vehicles/...0-right.html)? That might do the trick, but it appears to take only their little ring attachments. Can you attach something else to that rail - and if not, what's it used for?
I realize one option is to go full molle plate, but I'm hoping to avoid that - I won't need it 99% of the time, and it will just add weight, wind noise, etc.
I'm looking to benefit from someone's experience before I spend a few hundred bucks to experiment. Thanks if you have anything to suggest!
Old May 29, 2023 | 12:38 PM
GavinC's Avatar
QuickGrips work a treat. You could use them on your rack or crossbars. At $12 they are cheap and fit for purpose.
These like everything else attach with Thule M6 bolts designed to fit the Thule T-track on the crossbars. About $3 a bolt if memory serves but generic cheaper ones are probably out there. All in, your shovel mount will be about $16
Old May 29, 2023 | 12:49 PM
Mike_F's Avatar
Those look great but they appear to require a roof rack or cross bars. From how they attach do you think there’s a way to bolt them directly to the roof rails with no crossbars installed?
Old May 29, 2023 | 01:30 PM
GavinC's Avatar
My apologies. I didn't read your post properly. I don't have an info on attaching them to the rails directly .
Old May 29, 2023 | 01:35 PM
Mike_F's Avatar
I looked at them though - maybe they will work with the roof rail brackets from the Powerful UK roof rail eyes…
LR disco 5
Jan 17, 2022 10:05 PM
merrion13
Jun 28, 2021 12:11 PM
ashtray
LR4
Nov 7, 2012 11:02 PM
Batesy
Jul 16, 2010 06:16 AM
03discoman
Jul 6, 2010 06:21 PM
