Auto leveling possible?
If the newest Defenders can do this then I bet there is a module or something with an additional sensor. Or maybe there is an existing one in all Defenders and GAP could do some simple magic! If not, maybe that can be moved to a Defender without one and activated with GAP somehow. Otherwise your options are to manually do it, which you can get help with from an RV leveling module and app, or an XLifter-likes device for full integration.
I myself just level my LR3 by hand with GAP using guided calibration then yank the fuse without saving the settings. Done this dozens of time with no issue and the rig is level for camping/cooking out the kitchen. Thought of the XLifter, but it is overpriced.
I dont think some of you get how Rover auto leveling works. It levels relative to the ground it is on. There is no sensor in the LR3/4 for leveling, it is just reading the four height sensors. On a slope? It will average the wheel heights and match the slope angle. If you want horizon leveling - like ya do when you build a new deck on the house - then you do need a piece of hardware. In this case a sensor that is fix and calibrated on the truck to show what true horizon level is. This is what the XLifter does. It has a sensor inside and adjusts the air ride based on that.
![](https://cimg6.ibsrv.net/gimg/landroverforums.com-vbulletin/1280x854/00532cda43924f3a8db27f0a0ca10819_df7103df17c9d2b7e23afd36b9f49db6e9f16de7.jpg)
uncledd (08-28-2023)
LONERANGER7010
01-03-2020 12:04 AM
