Auto on/off
Old Jan 6, 2021 | 11:50 AM
TCole's Avatar
Default Auto on/off
I wanted to confirm on this forum before talking to LR service. The pool of knowledge here far exceeds my local LR experts.
When the car turns off under Auto on/off, just like every other car, the engine rpms should reduce to zero? I’m getting the “A with cross line” indication on the dash but the rpms do not go to zero when in “auto-off” at idle.
Note: comfort mode; climate off; auto-hold disengaged. Thanks.
Old Jan 6, 2021 | 12:22 PM
crewcabrob's Avatar
Hi,
Just making sure I understand: the auto stop start feature is not shutting the engine off and you get the green A with a line through it? I'm pretty sure that means it is not shutting off the engine. There are quite a few parameters that have to be met for the auto stop/start to work: battery level, climate control demands, ambient temp, drive mode... One must be keeping the system from shutting the engine off at stop lights.
Rob
Old Jan 6, 2021 | 01:11 PM
TCole's Avatar
Originally Posted by crewcabrob
Hi,
Rob
I see. Thank you for the clarification. The A-with-cross line is indicating that something is inhibiting the active start/stop. I read through the manual and none of the listed indications apply. Will have to straighten it out at the dealer. Thank you again for the insight. Much appreciated!
Old Jan 6, 2021 | 03:12 PM
DefenderSmitty's Avatar
It can be deactivated with button on the center panel. Useless anyway
Old Jan 6, 2021 | 03:24 PM
TrioLRowner's Avatar
Yes, particularly on a turbocharged vehicle -- hot turbos like to spin.
I try to turn it off every time I start the vehicle.
I suppose City MPG certification improvements, it might be worth 1/2 of a MPG or a bit more? It all adds up, I suppose.
Old Jan 6, 2021 | 10:18 PM
TCole's Avatar
Agreed, just annoyed its not working. Hopefully I don’t regret the fix.
My first thought was, wow! they did a real nice job on a seamless Auto on/off. Then realized it’s not even working 😅
Old Jan 7, 2021 | 06:41 AM
gmfain's Avatar
On my D5 I unpluged the signal plug on the VQM and works like a champ.
Try it on yours, should be the same????
File Type: pdf
Old Jan 7, 2021 | 09:54 AM
gmfain: Thanks for sharing the pdf document describing the battery and charging system. This is good info. to have.
are you saying disconnecting the signal line into the VQM disabled auto start or enabled it, for you?
Old Jan 7, 2021 | 11:01 AM
Mark1107's Avatar
Does amyone have a pic of our VQM and where its located in the defender?
Old Jan 8, 2021 | 04:32 AM
gmfain's Avatar
Yes it does. works perfect.
