Auxiliary Off-Road Lights
Old Oct 8, 2020 | 03:35 PM
avartanian's Avatar
Default Auxiliary Off-Road Lights
Has anyone installed auxiliary off-roading lights? If yes, how did you guys mount them and wire them?
Thanks,
Old Oct 12, 2020 | 09:22 AM
jayd33's Avatar
I think the strip of space in the grille between the Land Rover insignia and the front bumper is a good place to install some brackets. There's a guy on IG @noogoojee who installed low profile brackets and added some badass Baja Design lights on his LR4 that I believe we can emulate.
Old Oct 12, 2020 | 12:05 PM
umbertob's Avatar
The Land Rover oval is actually a concealed radar for Adaptive Cruise Control and Emergency Brake Assist, so you should probably stay away from it as much as possible to avoid false alerts.
Old Oct 12, 2020 | 12:52 PM
umbertob's Avatar
Double post, can't delete.
Old Oct 16, 2020 | 11:39 AM
Shodan01's Avatar
I ran a roof rack and LED light bar on the front (will send pics). What I did is follow the hood separations, into the A-pillar (under) through the channel at the top. Ran two black wires over to the roof rack, then covered with really thin small rubber strip, into the light bar- Since my Defender is black it all hid very well. It was harder to run the relay switch into the cab. I went to the other side of the hood and ran it on the inside of the snorkel into the door panel. Not perfect but looks pretty good
Freedom38
Mar 7, 2015 04:27 PM
skatelove303
Apr 14, 2011 05:41 AM
marks500
Jan 27, 2010 09:57 AM
leeb2761
May 28, 2009 07:42 AM
