Best offroad Jack that fits under load space?
Old Apr 19, 2023 | 04:42 AM
  #61
Defendit..'s Avatar
Originally Posted by rakusak
Does it have full support along the "tips" of the jack feet? I think you've created a bit a of a "hinge" condition? Maybe Im not seeing it correctly though.
Yes you're seeing it right . Just a little bit, at least it is recessed and stable now.
I could slide it to one side .. have to test that.
Old May 9, 2023 | 07:25 PM
  #62
Mike_F's Avatar
Rakusak replied to my earlier post asking if I had pictures.
I headed off road today, so I needed to be confident I could jack up my 110 if need be. The problem I ran into previously is that the combination of a SafeJack bottle jack and a Hi-Lift Off Road Base (ORB) is problematic. The shape of the rectangle that holds the bottle jack has a lip around it that blocks the valve used to release pressure and let the vehicle down. When I experimented in my driveway I didn't notice the issue until the wheel was in the air; at that point I wasn't able to lower the jack using the jack handle. I had to get a pair of vice grips to let the car down.
So this morning before heading out I used my dremel tool to gouge out a channel for the jack handle to get to the valve. It won't affect the strength or stability of the base, but it does allow me to operate the jack safely.
Pics below for anyone interested.
Yours,
Mike
Old May 10, 2023 | 11:48 AM
  #63
SilverSFR's Avatar
I hope you are not under the vehicle with that setup.
Old May 10, 2023 | 12:21 PM
  #64
Mike_F's Avatar
Not a chance.
Old Aug 25, 2023 | 08:39 AM
  #65
POPTOPP's Avatar
Reviving this old thread to learn if there's been any new ideas on how to raise the truck with air suspension high enough with a bottle jack to change a tire. Using blocks or extensions doesn't seem to be the answer since it's not an issue of getting the jack high enough to reach the jack point, but rather the amount of jack travel has to be greater that the suspension travel to get the tire to clear. A few weeks ago, since I couldn't get the tire high enough off the trail, I chose to lower the trail by digging out underneath the tire. Not something I want to make a habit of doing.
It seems the only sure way to do this is a two-step process. Jack the truck up, settle it on a jack stand, use a block or extension and jack the truck up again off the stand. Any better ideas? I was thinking of this since it disassembles to a small profile for storage.
Amazon.com: BIG RED T43004 Torin Aluminum Jack Stands with Locking Support Pins: 3 Ton (6,000 lb) Capacity, Red/Silver, 1 Pair : Everything Else Amazon.com: BIG RED T43004 Torin Aluminum Jack Stands with Locking Support Pins: 3 Ton (6,000 lb) Capacity, Red/Silver, 1 Pair : Everything Else
Old Aug 25, 2023 | 09:14 AM
  #66
Mike_F's Avatar
Originally Posted by POPTOPP
Reviving this old thread to learn if there's been any new ideas on how to raise the truck high enough with a bottle jack to change a tire.
I believe you’re referring to air suspension models? My coils don’t seem to have that issue, but I admit I haven’t played with it since I put on rock sliders. Next dry weekend I have I’ll play with it again and confirm I can jack high enough to change the tire.
A question for the air suspension owners - wouldn’t this be a problem for the OEM scissor jack too?
Old Aug 25, 2023 | 10:43 AM
  #67
POPTOPP's Avatar
Yep, air suspension. (and I edited my post to make that clear, thanks.) The scissor jack has a surprisingly large travel so it does work. However, I had the "pleasure" of using it on the trail once. Something I never, ever want to do again.
Old Aug 25, 2023 | 12:20 PM
  #68
medsker's Avatar
I've never used it on my 110 but I was having the same problem on my Jeep with a lift kit and went with a double ram and that worked. It would probably work on our Land Rovers as well. The one I used is
HERE. HERE.
Old Aug 25, 2023 | 04:00 PM
  #69
POPTOPP's Avatar
Originally Posted by medsker
I've never used it on my 110 but I was having the same problem on my Jeep with a lift kit and went with a double ram and that worked. It would probably work on our Land Rovers as well. The one I used is HERE.
Wow! I did not know these existed. Already ordered. Thanks.
A Faceless Man
Apr 13, 2024 12:38 PM
WYRover
Sep 2, 2016 06:52 PM
4x4 Brad
Feb 20, 2016 08:37 AM
Prepilot_3ck
Aug 26, 2009 12:34 PM
lipadj46
Aug 16, 2009 07:48 AM
