Best Place to Buy Oil & Filter in U.S.
Would like to have the oil changed after 10,000 miles; I will take to the dealer for the 2 year service but in the meantime going to go to an independent shop. Thinking it’s best to bring the oil to minimize the odds of them using the wrong oil, any suggestions on where to buy online for delivery to the U.S.?
https://a.co/d/6p0UzHA
Filters are unique for each engine.
There are two specs for JLR, this is the later one although the numbers appear lower:
Awesome, ordered. Last question, probably the dumbest one yet, do you change the air filter every time you change the oil/oil filter?
Here's what I bought in case it helps:
Filter - Genuine LR Filter w/ o-rings
Oil - Liqui Moly LM22046 0W20 Top Tec 6600 Oil which meets JLR Spec
Oil Sucking Device - (Amazon) - Mityvac 7201 Manual Fluid Evacuator Plus with 2.3 Gallon Reservoir - this was big enough for all the oil in the motor in one go
