Biggest Tire Options for Stock 2022 Defender 110 on 18” wheels
Old Dec 24, 2021 | 08:03 AM
mnugent's Avatar
Default 275/65 Geolander
Originally Posted by Diggler25
Hello,
Need some help on fitting bigger tires for a 2022 Denfender 110S stock without lift rods. I have the 18” dark satin grey wheels. Planning to get the BFG KO2s. Will 285/65/18 fit without rubbing? I’ve seen some people fit 275/65/18 and 265/70/18 with no issues as well. Any suggestions would be greatly appreciated. Thank you!
I am using 275/65
A/T G015 tires on Terrafirma 18" steelies. Tires rub very slightly at access height, but have never rubbed when in Normal height. I would not go any larger without lift rods.
NOTES:
1. I also had to use 30mm spacers to get the wheels to work with the P300 brake calipers. (wheels and spacers from Lucky8)
2. if using the Geolander tires, you will need the 10-ply version to meet the load rating.
Happy Holidays!
Old Dec 24, 2021 | 08:16 AM
DonMitsu's Avatar
That’s a good looking rig you have there. Thanks for sharing. Is that the OEM roof rack?
Thank you, yes it is the OEM roof rack with a Colorado Fairing Co fairing to make it a little less noisy.
Old Dec 24, 2021 | 11:06 AM
dj200's Avatar
What psi are you running those tires by the way? Thanks.
35psi on-road, 20psi off-road.
Old Dec 24, 2021 | 07:22 PM
gb_junkie's Avatar
anyone on coils (and 18's) with bigger tires? looks like coils sit higher than the "normal" setting on air-equipped defenders. 265/70's (32.6") look like they'd fit. but I've been eyeing 275/70's (33.1")
Old Dec 27, 2021 | 02:46 PM
NoGaBiker's Avatar
I have a set of 275/70-18s from Kenda in the Klever RT601 model. Mounted on OEM steelies. These are my off-road setup -- I use the 20" OEM wheel/tire setup for almost all my driving.
The 275s require lift rods (I have 1.5s, not sure if 1.0s would work or not). And because of the rear brakes I have to run 30mm spacers also. There is a little bit of rubbing. I wish I had 265/70s, or even 255/70s instead.
Old Jan 5, 2022 | 11:24 AM
Sanctuary2325's Avatar
Just a quick picture post as I am gearing up to place my 22’s into a winter storage mode. My brother-in-law custom built this rack for me to hold the rims and tires. Please forgive the mess.
I am also looking for a recommendation for a moderately priced lift for the entire car (hydraulic) that will get her a few inches off the ground just to change the tires out or maybe inspect the bottom from time to time.
Old Jan 5, 2022 | 11:57 AM
GrouseK9's Avatar
"Nice rack!!" as they say....
There's a thread over here that has been covering where to lift the Defender, ways to do it quickly for winter/summer tire changes, and some good jacks (none of them are cheap, however). Good luck: https://landroverforums.com/forum/20...stands-105963/
Old Sep 6, 2022 | 09:03 PM
Marrduk24's Avatar
Hey guys
just posting on this thread to see if there are others that can share their experience.
what other tire sizes have you put on stock 18” rims (air suspension) without any lift and get no rub whatsoever in access height?
Old Nov 13, 2024 | 10:01 AM
queezy's Avatar
Originally Posted by mnugent
I am using 275/65... A/T G015 tires on Terrafirma 18" steelies... I also had to use 30mm spacers to get the wheels to work with the P300 brake calipers. (wheels and spacers from Lucky8)
@mnugent How real is the concern of the harder steel wheels chewing into the softer alloy spacers? (link)
Originally Posted by NoGaBiker
I have a set of 275/70-18s from Kenda in the Klever RT601 model. Mounted on OEM steelies... And because of the rear brakes I have to run 30mm spacers also.
@NoGaBiker Same follow-up question here, unless you are running steel spacers?
I want to keep my white 18" OEM steelies for both looks and off-road worthiness, but fitting bigger tires gets complicated quickly! I'm finding far more info out there about the more common and more road-oriented 20's and 22's which I'm not interested in.
Old Nov 16, 2024 | 08:28 AM
POPTOPP's Avatar
Originally Posted by Marrduk24
Hey guys
I'm running LT265/70R18 (32.6 in dia) with air suspension, no lift. I understand LT275/70R18 (33.4 in dia) will fit, but it it would be really, really tight.
Corgi_Express
Apr 29, 2026 01:41 PM
sddisco
Nov 18, 2016 12:17 PM
Tomahawk
Tires
Aug 17, 2013 08:24 AM
frat daddy
Jul 11, 2011 04:23 PM
devildog01
Dec 27, 2009 06:16 PM
