Body panel clips
![](https://cimg7.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/59a9471c_e1fc_4329_beac_a2cf25444516_25f5e72d8fbfd723a5f38f9232bbe1e75bb49ecd.png)
I was ordering something from PowerfulUk and just decided to "stock up". If you have anything else you want, I would add these to the order if I were you: https://www.powerfuluk.com/vehicles/...nder-2020.html
@WTFChuck - I like where you are going with those! I would MUCH prefer a cheaper alternative. It isn't like these should be that proprietary. My only concern is that those may not "give". I don't mind the concept of a "sacrificial" little clip if it gives before the expensive trim does. I think that's a brilliant concept. What I don't like is that they run about $2 USD each! I'd just be happier with a cheaper solution. Maybe it would be a perfect thing to 3d print. If only I had the skills, or the printer, or the time, or the give-a-crap, or.... Cheap & sacrificial would do the deed for me.
what did you remove to need these?
installing new side fenders, bottom rocker panel for mud flaps all require new ones of these but the new parts usually come with the clips.
after messing with these too many times i believe they break cause something needs to give when yanking the panels off. either the clips or the panel itself
the metal clips are a great idea but as mentioned they will scratch the body and instead of the clips breaking the panel that holds the clip will break instead.
![](https://cimg8.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/image_55e2e053ca1da0a93aa35531f9a51c220a4e7817.jpg)
GrouseK9 (02-01-2022)
GrouseK9 (02-02-2022)
emncfi
07-30-2020 10:17 AM
