Brake controller
I installed this one last week in my LR4. It works great, as do other proportional brake controllers by Reese, Redarc and Tekonsha:
https://www.trailerjacks.com/trailer...xoCokQQAvD_BwE
There is also wiring necessary from the towing bracket to a wiring harness in the rear of the vehicle, if you are adding a towing bracket post purchase. The part can be purchased from JLR, if necessary. If you order the tow package with the vehicle purchase, that wiring will be installed in the factory.
See this thread. It has all the info you need. Go with the Redarc brake controller. Took less than 30 mins to install and works great.
https://landroverforums.com/forum/20...roller-101917/
TrioLRowner (03-24-2021)
