Brake controller
Old Mar 24, 2021 | 02:28 AM
Morley8000's Avatar
Default Brake controller
Anybody no anything about electric brake controller for trailer towing in US. I will need one for my new V8
Old Mar 24, 2021 | 07:01 AM
Landy718's Avatar
I know Redarc makes a great controller.
Old Mar 24, 2021 | 08:51 AM
TrioLRowner's Avatar
You will need to purchase a proportional brake controller, along with the correct adaption cable which fits a new Defender. This installation is pretty simple, but requires you crawl under the dashboard on the driver's side.
I installed this one last week in my LR4. It works great, as do other proportional brake controllers by Reese, Redarc and Tekonsha:
https://www.trailerjacks.com/trailer...xoCokQQAvD_BwE
There is also wiring necessary from the towing bracket to a wiring harness in the rear of the vehicle, if you are adding a towing bracket post purchase. The part can be purchased from JLR, if necessary. If you order the tow package with the vehicle purchase, that wiring will be installed in the factory.
Old Mar 24, 2021 | 08:53 AM
Guapo's Avatar
See this thread. It has all the info you need. Go with the Redarc brake controller. Took less than 30 mins to install and works great.
https://landroverforums.com/forum/20...roller-101917/
Old Mar 24, 2021 | 09:58 AM
charlypm's Avatar
I saw on a thread somewhere about the Redarc fitting very nicely in the blank space below the light dimmer switch. My trailer guy likes them and said it would be an easy install.
Old Mar 24, 2021 | 10:01 AM
charlypm's Avatar
Old Mar 27, 2021 | 09:44 AM
1availablelight's Avatar
I use a wireless controller from Curtis
https://www.curtmfg.com/dm/echo-mobile-brake-controller
DonMitsu
Mar 27, 2025 05:50 PM
Ryan Bartlett
Oct 4, 2020 06:46 PM
bosshogt
Aug 8, 2012 08:17 AM
socuban
May 29, 2012 11:10 AM
talton
Aug 30, 2008 01:43 PM
