Bridgestone K02 road noise
for those following my many recent post i have upgraded my p400 to a v8. i have been running K02 on the p400 and ended up swapping the wheels to the V8
for some strange reason i am getting much more noise on the v8 from the tires. much more noticeable than before. I couldn’t imagine the v8 is any less insulated
i believe the tires are non directional but i did notice on the back of the wheel my shop had labeled each. unfortunately they didn’t label all of them and i couldn’t follow the pattern
i have around 3-5 psi differences in the tires. thinking maybe the lower psi or higher is causing the extra noise
anybody have any ideas on what’s going on
have a feeling that’s what happened but i don’t quite understand why that would make a difference if they are not directional
I run KO2's on my Jeep Wrangler and just had the car in for a service recently. It's been a while since I had a tire rotation done, so I asked they do this during the service. When I picked up the car the tire noise had increased significantly, even more noticeable with speeds over 60mph. After about a month and maybe 500+ miles the noise subsided and I don't notice it any more. If I recall correctly, they did diagonally rotate the front pair to the rears (reverse direction). Hope that helps with one possible explanation.
had around 8k miles on the K02. but it makes sense i prob randomly moved the one or both rears to the front and assume the rear has less wear
thanks. makes sense now
JoeTall
Range Rover L322 (3rd Gen)
02-27-2024 01:58 AM
KernowDiscovery
05-30-2014 10:44 PM
