Can the new defender be flat towed behind another vehicle?
The requirement is to place all four wheels on a flat bed truck or trailer and to lower the vehicle to access height before securing the vehicle.
To tow on four wheels, the transmission park mechanism must be released. If Neutral is selected, this will not help, as the transmission will place the gear in Park after 10 minutes. If you are towing, this will destroy the transmission.
There is no braking available while being towed on four wheels. The vehicle is heavy, so this will strain your RV.
The steering column must be unlocked before disconnecting the battery. The steering column will not unlock without the battery functioning.
THE VEHICLE CANNOT BE BACKED - even with FOUR WHEELS ON THE GROUND. To do so will destroy the transmission. The vehicle may only be pulled forward on all four wheels.
The vehicle may not be backed nor brought forward with only two wheels on the ground. To do so, will SEVERLY damage the transmission.
When towing on the ground, forward, with four wheels on the ground (never two), do NOT do so for more than 30 miles nor at more than 30 mph. To do so, will seriously damage the transmission.
Do NOT tow the vehicle if the rear locking differential was engaged at the point of vehicle failure.
INTERESTING QUESTION --- THANKS FOR ASKING
Seems the only practical method to move the vehicle not under its own power is on a truck or trailer with all four wheels stationary.
Kev M (03-29-2021)
Found this on the D5 site. I could not locate it in the new Defender manual:
File Type: pdf
File Type: pdf
I was paraphrasing from memory, and was very struck by the breadth of the limitation expressed .... the exact quote from the manual is:
"NOTICE Only tow the vehicle in a forward direction with all four wheels on the ground. Towing in a reverse direction, or with only two wheels on the ground, will cause serious damage to the transmission. "
One supposes rolling the vehicle off the flat bed, while in neutral and with the park release mechanism activated, is not sufficient movement to cause serious damage.
The manual notes: The recommended method for recovery/ transporting the vehicle is by a trailer designed for the purpose.
This topic is covered under the subject of "vehicle recovery" in the manual.
V8DEFENDER90EUROPE
Defender
01-14-2023 11:23 PM
