Can our defender 2 do this?
Just saw this on YouTube. Can our defender 2 do this? Too excessive? Are these diesel discovery or gas powered? If we seal our raised intake will it take this beating. Impressive!
https://youtu.be/wetdTsck_vo
Possibly but the snorkel is irrelevant in this case. 3ft is ok but even with the snorkel, you'd be managing the entire engine & drive train, Personally, I'd give it 24hrs and try again the next day ...a hydro locked engine will write off a Defender regardless of age/model.
If you tried that with the current D110/D90 the system would freak out on wade sensing and say get the F back out beyond 3ft. Even with a snorkel.
Yes it might run once — during this crisis on the video.
but, his diffs and trans are now filled with water; his electronics shot and his engine intake flooded.
One could toughen the Defender to go deeper than what is allowed as is from the factory - the next step would be to add pressure equalization seal vents on the differentials.
The OEM snorkel is primarily about stopping sand and dust ingestion , not water.
ARB Diff vent extension kit
umbertob
Apr 13, 2021 11:12 PM
