Can our defender 2 do this?
Old Aug 11, 2021 | 10:06 PM
sblvro's Avatar
Default Can our defender 2 do this?
Just saw this on YouTube. Can our defender 2 do this? Too excessive? Are these diesel discovery or gas powered? If we seal our raised intake will it take this beating. Impressive!
Old Aug 11, 2021 | 11:01 PM
Lnberger's Avatar
https://youtu.be/wetdTsck_vo
I wouldn't attempt it unless you had an actual snorkel that is all the way to the intake manifold. The raised air intake isn't water tight.
Old Aug 12, 2021 | 02:39 AM
Ace7711's Avatar
well that is one way to clean your underside of the car!!! :-)
Old Aug 12, 2021 | 05:10 AM
gwelland's Avatar
Possibly but the snorkel is irrelevant in this case. 3ft is ok but even with the snorkel, you'd be managing the entire engine & drive train, Personally, I'd give it 24hrs and try again the next day ...a hydro locked engine will write off a Defender regardless of age/model.
If you tried that with the current D110/D90 the system would freak out on wade sensing and say get the F back out beyond 3ft. Even with a snorkel.
Old Aug 14, 2021 | 08:28 AM
TrioLRowner's Avatar
Yes it might run once — during this crisis on the video.
but, his diffs and trans are now filled with water; his electronics shot and his engine intake flooded.
One could toughen the Defender to go deeper than what is allowed as is from the factory - the next step would be to add pressure equalization seal vents on the differentials.
The OEM snorkel is primarily about stopping sand and dust ingestion , not water.
Old Aug 14, 2021 | 03:32 PM
NoGaBiker's Avatar
In the Jeep world we just extended the vents with a piece of tubing up to however high we needed for the depth of water we anticipated. Is that not what you do for LRs?
ARB Diff vent extension kit
Old Aug 14, 2021 | 06:20 PM
yes, same idea.
I have never waterproofed a JLR product -- maybe some day?
Old Aug 14, 2021 | 06:44 PM
GavinC's Avatar
"Hold my beer" Leyland Brothers probably
20mins or so in
Marco Kim
Apr 13, 2023 09:47 AM
_Allegedly
Mar 22, 2023 10:48 PM
umbertob
Apr 13, 2021 11:12 PM
ellebarto
Sights N Sounds
May 26, 2016 03:09 PM
TRIARII
Sights N Sounds
Oct 4, 2013 12:23 PM
