Check this before you have a flat
Old Dec 30, 2021 | 12:19 PM
RH5555's Avatar
Exclamation Check this before you have a flat
Pictured below is a potentially handy device that is included with your jack and wheel brace. It is a cone that you screw onto the uppermost lug on wheel (or spare tire carrier) to aid in positioning a tire prior to engaging up other lug nuts.
When we tried to use it on our 19" alloy wheels we discovered the fat end was a tiny bit too fat to fit through our alloys - and therefore useless. When I got home I ground a tiny bit (maybe 0.01") off the diameter of the fat end so that it now fits through our alloy rims. Next time we'll be set! I urge others to check the fit of these super-useful cones before you need them!
Old Dec 30, 2021 | 01:21 PM
Defendit..'s Avatar
It is a handy Tool supplied with the alloys. ( 5094 in my case)
unfortunately not useable with my steel wheels ( 5093 )
Old Dec 30, 2021 | 11:06 PM
WTFChuck's Avatar
Strange that I just used that device/tool when removing the front wheels to install mud flaps, and mine was not conical, but the same diameter through its entire length. Worked as designed and intended. Much easier to lift the wheel onto the lug extension, and with a gentle wiggle, seat the wheel firmly on the hub with little lifting and effort. Check with your dealer. When I got home the after picking mine up, and digging through every corner, I discovered that I was missing the towing eye. Called my salesman immediately and went back the next day to retrieve it.
Old Dec 31, 2021 | 06:44 AM
_Allegedly's Avatar
Mine didn't have the tow eye when I picked it up too. They told me the XD does not get it because it already includes factory rear eyes.
Old Dec 31, 2021 | 09:49 AM
WTFChuck's Avatar
I was expecting the same reply from my salesman, but found other postings and pictures of the cargo storage area with the tow eye neatly fitted in the space provided, and went armed with that. He and I walked out to some other vehicles on the lot, where he was going to grab one, but couldn’t find one. When he did find one, it was a different size, as I showed him in the photos I had. He said he would locate one and called the next day informing me that, and I was able to pick it up on a subsequent trip. I was almost waiting for him to say the same thing your dealership said, about having the factory rear eyes, but if your vehicle is not able to be recovered from the rear, you still need the tow eye in the front. Read that pertinent section in the manual about towing and you will see the procedure requires you to remove a panel under the front bumper by turning a few tabs and insert the towing eye into the threaded receptacle for a tow truck driver to winch the vehicle onto a flatbed.
Old Dec 31, 2021 | 10:05 AM
_Allegedly's Avatar
​​​​​​I do tend to agree with you but I picked it up about 4 weeks ago and got it about $2k below sticker and that was the only thing that seemed to be missing before I went back to sign the papers so I reluctantly just shrugged my shoulders on that one.
And maybe whatever the other empty slot is at the back left?
Old Dec 31, 2021 | 10:16 AM
NoGaBiker's Avatar
Wouldn't the front recovery point negate the necessity for a screw in recovery hook?
Old Dec 31, 2021 | 10:39 AM
WTFChuck's Avatar
I agree with your statement, but while picking up a new vehicle close to $75k, I wanted all those spaces filled. And I got just that. And the gloss black rear upper rear panel had a slightly hazy look to it when viewed under certain lighting conditions. I was going to be ok with that but my girlfriend spoke up, said, ‘no that’s not the way it should be,’ they ordered one on the spot and replaced it 3 days later. My favorite line from ‘Breaking Bad’, No half measures.
Old Dec 31, 2021 | 11:06 AM
_Allegedly's Avatar
Well... this kinda clears it up.
From the workshop manual new vehicle prep section.
Looks like they're just tossing it aside.
Old Jan 3, 2022 | 10:49 AM
GavinC's Avatar
Back left slot is for something related to the diesel models. A funnel of some sort to add a magic fluid. Sorry I'm a bit of an idiot when it comes to these things.
