Check this before you have a flat
Old Jan 4, 2022 | 02:27 PM
  #21
_Allegedly's Avatar
Originally Posted by NoGaBiker
So where does it screw in in the front of the truck? I’ve never looked for a spot, since the lower permanent one is readily apparent. Is there a trap door like on the front of Porsches that can be removed so a tow loop can be installed for track days?
Beats the living hell out of me. I don't actually work here.
It could just be called "front/rear" even though it isn't actually ever used at the front? Maybe they use it in the rear as a lash point only during transit and not for actual prohibited towing?
I'm going with "I didn't get one but life usually works out really well for me" so I can't care.
Old Jan 4, 2022 | 05:28 PM
  #22
Dan Hairy's Avatar
There is nowhere on the front of the new Defender for the two hook to be screwed into, if you need to tow from the front you use the permanently attached tow eye that is hidden behind the front undershield. If you have the two rear tow eyes attached then there isn't anywhere for that tow hook to be screwed into either at the rear as the optional tow hooks are in place of the screw-in mounting. The two rear tow eyes aren't just for towing the vehicle backwards they can be used when you are recovering another vehicle.
Fallstaff
Feb 3, 2018 01:35 AM
CarParter
Jul 18, 2017 09:01 AM
calebbo
Jun 16, 2016 08:00 PM
Landzu
Oct 16, 2007 06:49 AM
s4lex
Mar 26, 2007 01:36 PM
