CHEQUER PLATE WHEEL ARCH TRIM KIT pics?
So, is this an alternative to the actual wheel arches? You use on or the other? Is it functionable or just for looks? I might go this route in case there is real protection in trails, since not a fan of the wheel arches.
jusmax88 (11-18-2022)
Regarding 'functionality"... they are plastic, but they ended up doing a nice job of blocking debris (rocks, pebbles, etc.) that get kicked up and hitting that part of the vehicle. I bought them because i thought they looked cool, but I've realized that the plastic is much more resilient than the paint that would probably have chips in it by now.
Also -- I just realized (looking at my photo above)... the plastic protects the flared area of the fenders. The flares stick out 1-2" wider than the vehicle, so if there was branches, etc. that you might brush with the car, the plastic would take the damage instead of paint.
The install was easy - go slow, and ideally have someone else help you pull the tapes so it doesn't slip when adhering to the vehicle surface.
Functionally identical covers are available on aliexpress if you feel like taking the chance. I was thinking of picking some up and then trimming them to work with my extended wheel arches.
My experience has been that the extruded plastic parts available on the grey market are identical in every way to the JLR stuff and may even come from the same moulds / manufacturers - it's fairly common in China for a portion of the line to be diverted for factory door sales or listing on aliexpress.
