Clearance Height Screen with New Tires
Old Aug 5, 2025 | 09:32 AM
M.C. Shirt's Avatar
Default Clearance Height Screen with New Tires
Hi, I just put 265/70/R18 K03s onto my 2023 110 (stock air suspension, not lift rods, with 5094 alloys). Does the clearance height screen in Pivi take the larger tires into account? Is there an adjustment I can make if it doesn't? Thanks
Old Aug 5, 2025 | 10:30 AM
CincyRovers's Avatar
255/70R18 is the OEM tire size for 18" wheels, so the measurements wouldn't be any different. It doesn't adjust depending on the tires, and there is no way to manually adjust it, unfortunately.
Old Aug 5, 2025 | 10:35 AM
M.C. Shirt's Avatar
Thanks. Typo - I meant that I got the 265/70R18 (edited original post). Same issue though. Thanks for the response. Bummer that you can't change it.
Old Aug 5, 2025 | 10:41 AM
I'm also running a tire size 1/2" larger than the OEM diameter. You'll just have to remember to add an extra 1/2" when looking at the screen.
Old Aug 5, 2025 | 12:49 PM
nashvegas's Avatar
No.
I actually screwed around for a few hours in the pivi system trying to code it with the GapIId tool in CCF settings, which I thought might work -- ie manually coding in heights (to account for my higher truck with roof rack, lift and bigger tires.
It’s not possible. Kind of lame TBH. Should be possible.
Old Aug 5, 2025 | 05:40 PM
GavinC's Avatar
No.
Yes. This would be useful if that screen was configurable. Like setting up a custom trailer profile. Add lights, lift, rack, tires etc.
Similarly being able to tell the vehicle "I am airing down" please adjust TPMS warning accordingly" would be handy. The latter is something the Ineos can do.
djkronik57
Aug 6, 2024 06:15 AM
Amadreas
Nov 25, 2021 09:21 PM
Chum
Oct 6, 2021 06:35 AM
ycc456
Tires
Jun 21, 2014 01:05 AM
Eniam17
Aug 10, 2013 05:50 AM
