Coil spring lift kit
Pre order for lift springs for coil equipped d90 and d110 is now available. Front coils provide 1.5 inches of lift with 250lbs of added load. Rear coils provide 2 inches of lift with 750lbs of added load. The stock coils were tested to provide correct rates for lift springs. Stock ride quality is maintained! Click on link below:
https://www.etsy.com/listing/1160897916/2020-new-defender-lift-springs-made-to?utm_medium=SellerListingTools&utm_campaign=Shar e&utm_source=Facebook&share_time=1644252117000&utm _term=so.slt
below photo is our 90 that already had a 4 inch subframe lift with 35 inch tires and stock coil springs. We added the custom coils to test which brought the lift to 6 inches (Pictured). Coil spring lift didnt noticably change the drivability.
Would we be able to see what an otherwise stock Defender looks Iike with the lifted coils? Personally I'm interested in pics of the #90 and #110. The shown #90 with 6" of height looks pretty tall to me, as someone who plans on driving the truck nearly daily. Obviously I can see the benefit when rock crawling, but for day-to-day use it's out of the question.
One branch-off that I'd love to see after modifications like these: Answers to common questions.
- What size wheel/tire can you specify and run after completing the coil swap?
This is great @sarek ! The more I look at the height of my coil sprung 110, the more I'm wanting just a little lift for piece of mind. Assuming the stock shocks are fine taking the extra height?
mopadzi (02-09-2022)
