Crossbeam Rattle
Old Apr 26, 2022 | 01:13 PM
verrilli's Avatar
Originally Posted by swajames
there’s a common issue with the A pillars that can create a noise while driving that sounds like crinkling. Mine has it a little on the passenger side, but only at high speed and it’s something that can wait until a scheduled service. If you have that on the driver’s side, that might explain why the noise appears to come from the general area between the windshield and the steering wheel. There are plenty of posts about this issue and TSBs on how it gets fixed.
Thanks for the info. I found the long thread and the service bulletin for 2020 Defenders, https://landroverforums.com/forum/20...-speed-101509/
Mine is a 2022. Shouldn't it be fixed from the factory by now? Anyone else with a 2022 have the issue?
Old Apr 26, 2022 | 02:17 PM
swajames's Avatar
It's still an issue.I have it on my 2021, and it's still out there for some 2022 owners as well. From the way you describe the sound, I think it may well be what's causing your problem.
Old Apr 26, 2022 | 02:18 PM
Xm83's Avatar
2022 here.
Old Apr 29, 2022 | 11:48 AM
ponder's Avatar
I have a MY22; and have had the rattle near the driver left air vent near the door. More aggressive when I’m off roading / on washed out roads.
similar scenario when I pinch the soft fabric in front of the vent of the cross bar it would silence it.
based on this thread I opened it up and popped out that bottom black trim.
one of the metal clips was rattling around in the enclosure. And then I stuck some soft fabric from Michael’s between the instrument panel and the touch plastic beside it. I think for me that’s where the rubbing is.
hoping this solves it.
Black trim you pull down, once you’ve removed the side grab panel and extra screw holding in trim
Pull straight down
Old May 4, 2022 | 10:15 AM
philca's Avatar
Update:
Put in the felt padding from Amazon that Paul recommended earlier to the lower and upper plastic areas and that seems to have fixed the issue.
Big thanks to Paul on explaining how to remove the upper plastic area, never would have figured that out on my own.
Marco Kim
Defender
Feb 2, 2022 07:32 PM
Chief65
Sep 14, 2021 08:14 PM
Ryan Leestma
Jul 11, 2018 08:37 PM
MyRoversNameIsCarl
Aug 19, 2015 02:51 PM
snowdude
Sep 27, 2013 10:27 AM
