Defect in rear exterior doors paint chipping
#101
#102
I am running classic flaps on my 110X from day one, I also installed extended arches that I color matched to the rest of the X trim. Truck went in service Dec 28th, by the time I made it through the thick of the winter months here in NY and did a hand wash I noticed I picked up a chip or two in the rear wheel arch extension (the piece that attached to the rear door), also a couple very small nicks in the lower trim. Now I am running 275/60/20's on redbourne alston wheels with 25mm offset which makes them stick out 16mm further than stock wheels. I think on stock wheel/tire with classic flaps your paint would be safe. At the point I found the damage I touched up the small chip or two and covered the lower body and the arch extension with a panel of PPF (self healing type). I have not noticed any progression of damage since adding the film over the past 2 months.
#103
The cost of the mud flaps including installation labor should not exceed $800 for a set of 4.
One can always look at the official JLR installation manual and see how many recommended serviceable hours each installation should take. That would give you an estimate on the labor cost by simply using your local dealer hourly labor rate.
#104
#105
Seriously, installing the extended wheel arches is not difficult to do. Watch the PowerfulUk video, hire a teenager to rage, rip the old ones off (the new ones will cover any adjoining "issues"), pull off the two-sided tape cover, and snap them in. The toughest part was unplugging/plugging in the USA spec lights (on par with changing a battery cover). If someone can change a tire, they can do this. Not being judgmental here, just trying to encourage folks to do this one on their own.
GavinC (05-18-2022)
#106
Still have to do some protection on the front. Not nearly as much issue up there so I guess I'm being a bit lazy..
#108
I had a close look after washing my Defender this weekend. I can confirm chip damage to both the paint and gloss trim on both rear doors. Some major chips in the paint actually. I have done around 12,000km and only a few gravel roads. I have had the non-classic mudflaps since new. I can confirm this mudflap design does not protect and I guess I’ll be going back to the dealer soon to see what can be done. A major design flaw IMHO for a vehicle marketed as off-road. Other than that, I love the thing.
#109
You are correct. It's the removal of the wheel well lining, removal of the nut that holds the heat shield, lifting the heat shield, cutting the template, drilling the bumper, installing the mud flaps, reinstalling the rest. The genuine LR instructions also states the removal of the wheels. So to me personally, that's too laborious for mud flaps. Hence I am going to see if there is any aftermarket plug and play alternative.
