Defect in rear exterior doors paint chipping
Just saw in one of the Defender Facebook groups, someone had this Feynlab ceramic coating applied. This looks like it could be a good way to prevent the chips.
https://www.feynlab.com/product/feyn...mic-version-2/
I'm very curious though on how any of these protective coatings look after applied. Are they noticeable to the eye?
Interesting is this different than film product I've heard some people do? Does this Feynlab product need to be professionally installed and, if so, wonder what the cost is. I asked my JLR about having the film product done and the issue becomes having it customized to just cover the lower door boards and wheel arch versus say the premolded front grill.....the cost I was quoted was below having the fixed side step done but not by much....so I just figured add the fixed side step because I have kids. I'm going with the factory side step because I was cautious of the after market ones this early on and I'm not confident I'd be able to install them myself.
I too am curious how it looks once applied. It seems like it just makes the truck look a little glossier if anything.
Is this confined to any one color or all colors? Does it appear on white and other colors as well as the Santorini Black? Is it mostly on the gloss black trim on the X or X Dynamic? Seems it's more prevalent and I wonder if the entire trim as well as the body is painted at the same time vs the dark gray cladding being added later. It wouldn't seem likely to paint that way but ???
From the Feynlab site:APPROVED SURFACES FOR APPLICATION ONLY: – DO NOT apply to unapproved surfaces
- Clear-coated painted surfaces (see warranty terms and conditions for approved manufacturers & vehicle types)
- Black textured plastics (test if unsure)
- Headlights & Tail-lights
- Black piano trim
- Clear-coated painted wheel rims & calipers
Update from my trip to the dealer this morning...my service advisor says they are going to take a look at the paint and see what they can do to correct the chipping so far. He also said there 'isn't much they can do about' the plastic trim.
Going to let them buff out/touch up the paint, and taking the truck to my vinyl installer next week for custom paint protection film.
As far as the ceramic coating materials go, most shops will (or should) tell you that they can't prevent rock chips. They are a very hard surface for sure, but their primary purpose is to aid with shedding mud/dirt/etc from the vehicle...not to protect from rock chips. Here's a quote/article (no affiliation with the site, just one of the first google results on the topic I found) specifically referencing the Feynlab product mentioned above, and stating that the best way to prevent rock chips is by using a film based product.
'Although ceramic coatings are bullet-hard, they are not bullet-proof. Rocks and pebbles blasted at your car from passing vehicles will damage the ceramic coating, and could affect the paint underneath. It’s definitely better to have a ceramic coating in this scenario than not, but you shouldn’t expect the ceramic coating to deflect significant impact.
To truly insure against rock chips, you would want to check out Paint Protection Films. These films are much thicker than a ceramic coating and are pliable to absorb and deflect impact.'
- https://cjsautobling.com/ceramic-coa...nd-rock-chips/
I believe this is different than film, this is a spray on professionally applied product. The guy on FB said it took 4 days and cost $1200 for the installation. It sounds like the protection lasts for 4-5 years.
