Defender 110 delivered without USB/power outlets in second row. Easy fix?
Old 11-08-2022 | 12:07 PM
TrooperDefender's Avatar
5th Gear
Thanks for the pictures. What’s the part number and where did you buy the USB A port for the front passenger dash port. Thanks
Originally Posted by Trekkie
OK, After psyching myself up I got to work today on hooking up the replacement USB ports I ordered. I discovered I ordered USB-A instead of C, but it isn't that big of a deal to me and well couldn't return them anyway. That said. The hardest part obout this was getting the sticky foam/tape that was wrapped around the plug and folded back onto the wire through those tiny damn holes. There was some kind of foam, and then a ridiculously sticky tape around it. I'm sure if I had instructions I could have taken it apart more but I magically stuck my finger through the holes and picked at it, then got some regular scissors and snipped it a hundred times, and then hung ho'd the first one (and damaged the insulation some, electrical tape to the rescue) but I got the three ports installed in the missing position. I'm annoyed I had to do this still, but glad the connectors were there. Some photos that were taken in-between curse words and grunting. Really tore up my thumb on the front, it's a metal brace thing that you stick through and it's not sharp but it's not skin friendly when you're trying to pry.
Foam/Taped end stuck in the hole
after many colorful metaphors I got it out, not sure if you can see but I damaged the ground. wrapped that in electrical tape and put it back
first port in, testing with an old 3DS in case it fries it, it didn't!
with both in. I straightened out the hole plus
The front one. It's in there, but holy crap was that one harder to get too. But I got it eventually. The hardest part was pulling it through the METAL hole which bit my thoumb
all back in, and working great
only injury
  #52
Old 11-08-2022 | 12:36 PM
EasternShoreDefender's Avatar
Post #35 in the thread.
  #53
Old 11-08-2022 | 12:45 PM
Trekkie's Avatar
Originally Posted by Hula-2
It’s hard to tell from the myroverparts website what type of USB port the parts are compatible with. When you receive your LR128008 ports, can you confirm whether it is a USB-A or C? And whether you had success connecting to the two pre-wired holes? Thanks in advance!
The 128008 was A. I didn't catch that when I ordered, not a big deal to me as we have both cords everywhere. I doubt A charging cords will be gone before I buy another car
  #54
Old 11-08-2022 | 12:46 PM
Trekkie's Avatar
It was the same part number for all three spots, but yes that linked #35 has the URL
  #55
Old 11-08-2022 | 02:10 PM
DrPizz's Avatar
Can confirm in my 2023.5 110X, no USBs in rear or passenger dash area (just center console area). Wireless charging pad is there and functional. Built 8/24, delivered to dealer in November.
GrouseK9 (11-29-2022)
  #56
Old 11-08-2022 | 03:09 PM
Defender novice's Avatar
4th Gear
Default Part number
The USB-C outlet part number LR150128.
ficklma1 (11-09-2022)
  #57
Old 11-14-2022 | 03:54 PM
XplusYplusZ's Avatar
I collected my MY23.5 110 D250 X-Dynamic 3 weeks ago. The dealer made a special effort to alert me to this missing usb issue and provided me with a letter confirming the ports will be retrofitted when supplies are available.
Im not sure when that would be, or why I can buy them on eBay but JLR can not. But it’s encouraging to hear them confirm they will commit to fitting them for free.
The following 2 users liked this post by XplusYplusZ:
jusmax88 (11-14-2022), Xtabi (12-04-2022)
  #58
Old 11-14-2022 | 03:59 PM
Hula-2's Avatar
Agree. But after traveling this past weekend with our brand new 110, it was unnerving to hand our only key fob to the hotel valet. Can’t wait to get the second fob.
The following 2 users liked this post by Hula-2:
Huc (11-17-2022), jusmax88 (11-14-2022)
  #59
Old 11-28-2022 | 06:57 PM
dj200's Avatar
PowerfulUK posted a video on adding USB to the passenger-side dash “shelf” location.
They remove the glove box to get to the power cable, but it looks like you could reach in through the hole with a small hook and grab it.
The following 2 users liked this post by dj200:
GrouseK9 (11-29-2022), Xtabi (12-04-2022)
  #60
Old 11-28-2022 | 08:33 PM
https://youtu.be/mruYwM9DSz4
That seems excessive considering a few have done it on here with their bare, though scuffed up, hands. I plan to use a tool like the one pictured. I've had it sitting in my tool chest for years and think I may finally have a good use for it.
The following 2 users liked this post by EasternShoreDefender:
dj200 (11-28-2022), ficklma1 (11-29-2022)
Quick Reply: Defender 110 delivered without USB/power outlets in second row. Easy fix?
