Defender 130 Radio stayed on
2023 130 SE
11.4” Pivi Pro
SXM
Pulled into the garage. Shut engine off. Can’t tell you if everything went quiet when I exited the car. Took my fob with me, dropped it in the usual spot in the house. Went out back with the pup. After 10 minutes or so realized I left my readers in the car. Went back to the garage without my fob as I don’t lock the car in the garage. I heard voices in the garage and was reaching for the Judge. Walked to the driver door and SXM was still on. I didn’t think to look at the screen when I realized it was coming from the car. Opened the drivers door, closed it, it cycled off.
Was that a fluke? Or an indicator of worse to come? Don’t want to kill a battery……
Thoughts?
11.4” Pivi Pro
SXM
Thoughts?
2023 130 SE
11.4” Pivi Pro
SXM
Thoughts?
11.4” Pivi Pro
SXM
Thoughts?
Radio will stay on for about 10 minutes unless you lock the vehicle. If you want everything to power down on exit, double lock the vehicle.
PaulLR (05-13-2023)
mine functions the same way @lightning mentioned.
i do however lock the car in the garage. the way i understand it is pivi pro updates only happen when the truck is locked. i have a wifi extender in the garage as well so it a strong signal.
