Defender Roof Rack
The following 2 users liked this post by gridcityrover:
DefenderSISU (05-05-2023),
Ludders54 (01-22-2022)
I’ve used a mixture of Thule t-slot bolts, and various others off e-bay…………
Shovel fitted with Quick Fist grips, mounted to the rack with T-slot bolts and M6 nuts
ARB awning fitted with quick release clamps
Recovery boards now fitted with L-Angle brackets.
Frame fitted and now with Wolf boxes in place
Original recovery boards fitted with T-slots and thumb screw *****.
Close up of fixture mounts
Frame fitted with t-slots and thumb screw nuts
Framework fitted
CB aerial mounted to roof rails with fabricated bracket
Framework fitted
The following 6 users liked this post by Ludders54:
Bjs1234 (01-22-2022),
GavinC (01-22-2022),
GrouseK9 (01-22-2022),
johnsonmc2000 (01-22-2022),
Olmeca (03-14-2023),
and 1 others liked this post.
There are tons of T bolts in various threads that fit the rails of the roof rack in ¼ x 20:
National Hardware makes a ton of different black powder coated brackets used in construction that can be used to make loads of different brackets. Just roam the bracket section of an Ace Hardware or Truck Value Hardware. Home Depot really has a lousy selection. There are a myriad of tie down eyes that will go with the T bolts, again on Amazon.
This gizmo works quite well to access your rack and at the price, how can you not get one. I know it does not look cool sitting in your glovebox instead of being attached outside. Really, people are making the vehicles look as if they drove through a junkyard after being highly magnetized.
@Ludders54 that is great info. Do you have pictures of the quick release clamps you used for the awning?
It is a bit of a misconception on how the steps work. We used to use these things in climbing called "Bat Hooks." They where made by Chouinard and where super popular for "Buildering." They could let you hang from the seam in bricks. If you hung your weight directly on the hook nose, it would indeed chip off the brick and you would fall to your death, of course after saying, "Watch This." What they do is actually through the wizardry effects of physics (a class I was so good at in UCLA, I took it twice), It re-directs the force 90° to the sill on the big rubber foots. The Bat Hook did the same with the way the webbing hung off the hooks. I am still alive, so kind of a proof it works after climbing part of Reiber Hall. Later, I shudder at the thought, since I kind of developed a forebrain around 30. I say 30, since I was still landing on Aircraft Carriers during my 20's. That was defiantly a foolish occupation, but a clever, again, adaptation of physics.
I've climbed quite a bit too, and am familiar with all kinds of protection and aid devices. Rock is a bit different from the body and frame panels of a car. Every car is made differently of course, but the door latch receiver is made to hold a certain direction of force, and may not be built to handle the type of forces put on it by these kind of steps. Whether it's an outward lever, coupled with some downward force, it may deform from use over time. That force has to go somewhere. All I know is I put one on our subaru several years back and it flex'd the body panel holding the door latch like crazy just from me stepping on it once. Doing that over and over would definitely have caused problems Maybe the Defender is built better (certainly hope so) but I wouldn't use it if I saw any flex at all.
I have had one for several years now and have used it a lot on the Range Rover. Never had an issue. Now there is a tiny bit of difference in a Range Rover and a Subaru. If my Son's Subaru in Brisbane is any measure of build quality, it would not be a fair comparison. I think he refers to it as the some kind of S box he drives to the mine to be thrashed and discarded after two years. He replaced most of the suspension after just a year going back and forth to Hail Creek from McKay. The painful part was the insane prices for subi parts in OZ. It turned out to not be the economic car he had hoped for. Since it literally fell apart before his eyes. He ended up with an LR4 one of the other engineers sold him when he departed for another mine in another country. Actually sold that for a bit of gain when he departed.
Ludders54 (01-24-2022)
Sure hope the Defender has stronger metal there than my old Subie. Just to avoid any confusion though, I wasn’t concerned about flex in the step itself. It’s the outward pull on the latch which was the problem on the subie. I could see the metal panel holding the latch flexing. That’s the flex to watch out for. The latch itself is probably perfectly fine. It’s the panel holding the latch, which was likely designed for sideways shear strength, not outward pull. May be fine on the Defender as you say, but it’s most definitely an issue on some other cars. I’d watch it either way.
