Diff Oil Change - New clunking sound
Old Dec 6, 2022 | 08:21 AM
sarek's Avatar
Originally Posted by TrioLRowner
Here is a picture of what Sarek is describing within the rear ediff, for those interested......... I do not know for certain if Magna is manufacturer which JLR uses; but, I expect they are.
https://www.magna.com/docs/default-s...rsn=6949b18f_2
Enjoy !!
The differential is a Dana product, but the same theory in general. The transfer case is however a magna product with similar tech
Old Dec 7, 2022 | 09:30 AM
Ericlockheed's Avatar
Originally Posted by sarek
This type of bulletin brings me back to my dealership days. Under investigation....Change the oil 2x. . The differential in the rear locker equipped vehicles utilizes a torque on demand design. This uses a PWM drive motor and ball ramp with clutch packs. This design allows variable levels of locking requested by the ECU. There is a special type of friction modified synthetic fluid used in these type of torque on demand units to help promote friction for the clutches. Over time, these clutches and ball ramps wear and the clutch material contaminates the fluid. We have seen excessive wear of these units for no real reason. Fluid type and quality is crucial for these units. Non locking rear diff equipped units are just a conventional differential with not much service or complex components.
Is this why you have been messing arnd with arb lockers?
Old Dec 7, 2022 | 08:09 PM
sarek's Avatar
maybe.......
Old Dec 22, 2023 | 11:42 AM
Gullywasher's Avatar
Default Defender 110 P 400 with transmission clunk
My P400 2022 110 SE had the clunk complaint as above, but was not in the group of Vin numbers for the service bulletin. I did convince the dealership to do the transmission flush procedure and it did help. There is no more clunk. I had this done before 50,000 miles, so they did it as warranty work as they should. I felt pretty strongly that they should address this.
Old Dec 23, 2023 | 05:08 AM
sarek's Avatar
I had a client that had the same symptom right before 50k miles. The dealership performed the bulletin and the symptom did go away for about 2 months and then came back and more severe. Then the client was then out of warranty and had to fight to get it replaced. Needless to say, make sure the visit while under warranty is well documented.
Old Dec 27, 2023 | 04:13 PM
Tucker Woods's Avatar
Originally Posted by mrmihai
I recently passed 50k miles on my 110 P300 and had the transfer case and center+rear diff oils changed (oils were dirty and cloudy already). Shortly after leaving the service shop I noticed a low thud/clunk noise coming from the rear/center of the vehicle, exactly where the rear-diff is. It is not a repeating thud and now happens rarely when pulling away at slow speed but is more likely to happen after a cold start. I can't seem to reproduce the sound on my own (manual gear selection, different stop/start behavior, etc.) and there is no CEL or code being thrown.
I took it back to the shop to assess and as is tradition we couldn't reproduce, even after letting the car cool off a bit. They raised it up to look underneath and no visible issues either. I also was watching the the 4x4i screen and there is no correlation of the thud with the lockers engaging/disengaging.
Any idea what this can be? I read it could be the incorrect oil or wrong quantity used but this was done at a trusted Land Rover shop and they verified with the dealer that they used the correct spec. I know when changing transmission fluid the computer has to recalibrate overtime or you have reset it manually, but apparently that is not part of the procedure for diff change.
Appreciate any insight or help here!
I have a 2020 First Edition Defender with the P400 engine. In my Owners Manual it says at 84,000 miles to replace the rear locking differential oil. Is it different for the P300? I see that you did it at 50,000 miles.
--Tucker
2023 RRS Dynamic SE P400 Giola Green (Current)
2020 Defender 110 First Edition Indus Silver (Current)
2020 Discovery HSE Luxury Si6 Fuji White (Former)
2015 RRS Autobiography Fuji White (Former)
2011 RRS Supercharged Fuji White (Former)
2008 LR2 Fuji White (Former)
heidenseek
Sep 19, 2018 09:18 AM
djkronik57
Jun 2, 2017 02:40 PM
dz5bxm
Jun 10, 2015 07:02 AM
DISCO JAK
Aug 15, 2013 11:12 AM
rick1701
Jul 17, 2013 11:53 AM
