Noisy Front Diff - 08 LR3
Old Sep 16, 2018 | 09:57 AM
heidenseek's Avatar
Default Noisy Front Diff - 08 LR3
I have an 08 LR3 with 136K miles that is making a growling/grinding sound the I believe is coming from the front diff. There is almost no change in the sound with change in engine rpm or vehicle speed. I do not really hear anything with the windows down only with the windows up.
I changed the front diff oil recently and the plug had a lot of shavings/black sludge stuck to it and the fluid was dark and metallic. Since changing the fluid it has gotten noisier. My question is how long can I drive on the noisy diff?
Old Sep 16, 2018 | 11:49 AM
The answer is until you can't. There is no way to know how long it will last. Could be a day or 10 years. Check and change the fluid again. The amount of metal in the fresh oil should give you a hint at how fast it's eating itself.
Check with Abran here on the forum he may have a good used unit for sale.
Old Sep 18, 2018 | 08:11 PM
spannermonkey's Avatar
For what its worth, if you have not changed the fluids in the T-case or rear diff, I would also do those too.
Old Sep 19, 2018 | 09:18 AM
heidenseek's Avatar
I did change all three fluids at the same time. T Case and rear diff fluid looked much better than front diff.
Snas2013
Freelander
Jun 5, 2019 12:26 PM
LoireBlue
LR4
Feb 15, 2019 05:54 PM
DiscoCam
Dec 18, 2016 03:27 PM
Dirt Roamer
Jan 9, 2016 11:21 PM
dz5bxm
Jun 10, 2015 07:02 AM
