DV8 exhaust valve hack or controllers
Old Sep 11, 2023 | 08:32 PM
speedyj's Avatar
Default DV8 exhaust valve hack or controllers
Hi,
I have a 2023.5 and was wondering if anyone has found a way to bypass the valves to make them open all the time via a fuse or disconnect; and or has installed a valve controller.
looks like milltek makes one for their exhausts- which I am assuming uses the same factory valves? I am wondering if it would work with the stock muffler and valves?
https://www.motorsport24.nl/en/produ...valve-control/
Old Sep 13, 2023 | 10:48 AM
starbai's Avatar
In for answer. I actually didn't know the factory exhaust had a valve on the exhaust.
Edit. I just realized DV8 = defender V6.
My lowly P400 likely doesn't have the valve.
Old Dec 16, 2023 | 07:14 AM
DGG9's Avatar
7th Gear
Fitted the valve controller on my V8 and it works fine though not a huge sound improvement unless you pair it with an exhaust upgrade/mod
Ben Matheson
May 15, 2019 04:41 PM
Trunk Monkey
Dec 21, 2012 08:36 AM
littlestwoo
Sep 9, 2009 02:28 PM
EVN137
Jun 15, 2007 06:54 PM
jochvalve
Feb 11, 2007 04:45 AM
