Early Impressions—2022 Defender
Old 11-30-2021 | 12:08 PM
WTFChuck's Avatar
Sanctuary2325: I believe the global window feature only allows the windows to open, but because of safety issues like a child or pet in the car and possible injuries, that is disabled for the US market. Not sure where I read it, but I believe that is the reason.
Old 11-30-2021 | 12:11 PM
Sanctuary2325's Avatar
Thank you. I am glad my dog is safe!
As a separate note gents, keep your eyes open for a chip upgrade or power boost for the I6. I would love another 30 to 50hp at the expense of gas mileage if necessary. Certainly don’t want to void a warranty.
Old 11-30-2021 | 12:14 PM
_Allegedly's Avatar
It's here:
https://landroverforums.com/forum/20...i-tune-109283/
Old 11-30-2021 | 06:29 PM
freepower's Avatar
Originally Posted by swajames
@Sanctuary2325 Is your car set to normal or light load for the tires? All the ones I tested including the one I bought came from the dealer with tires set to normal load and had them inflated to close to 50 PSI. If you haven't already done so and generally meet the conditions, adjusting tire pressures down to the the light load setting will make the ride even better. It's good when set to normal, it's great with the tires set to the light load lower pressures (make sure you adjust the setting so the car knows you want the lower pressures)
I run my BFG KO2s on my current vehicle at 32 PSI and its a really smooth ride. Tires also lasted to 70k miles! When you say light load down from 50 PSI are you thinking 35 PSI?
Old 12-01-2021 | 02:10 AM
swajames's Avatar
Close, the normal load recommend pressures are 47 front and 50 rear, and light load drops these to 34 and 37 respectively. I don’t know if you’d get a TPMS warning at 32 or not, but you’re not too far below for the fronts at least. Moving to light load really did improve the ride, it’s well worth it.
WMN (12-01-2021)
TheMoke
08-08-2021 10:43 PM
turboldt
08-31-2020 07:00 AM
Tucker Woods
08-09-2020 08:48 AM
preeble
03-06-2019 04:18 PM
HSE_LUX
Discovery Sport
37
09-28-2015 01:30 PM
