Engine noise in cabin
Yes. Change the following two parameters to “not fitted”. Let the car sleep for 10-15min, etc., and you’ll be good to go. I did it in my P300 and it’s worlds quieter on the freeway. It’s rather shocking just how much noise was being piped over the speakers.
1) MultiCAN-584 NextGenPwrTrnSQ
2) MultiCAN-585 ActSndDesignPwrlvl
I got the same fault, it's no problem untill now.
https://landroverforums.com/forum/20...ummary-118688/
and
Defender2.net https://www.defender2.net/forum/topic89347.html
Are these the correct parameters to select for the two CCFs listed?
Just to clarify from others, the faults that occurred, if any, were they clearable or did you have to revert to prior settings to clear?
