Epb
RTFM at https://www.ownerinfo.landrover.com/.../proc/G2397954
The Electric Parking Brake (EPB) switch is located on the switch pack between the steering wheel and the driver's door. Operate as follows:
NOTESTo prevent automatic operation, with the vehicle stationary, pull out the EPB switch to the release position before selecting P.
The EPB applies automatically if the vehicle’s electrical system is switched off and the vehicle's speed is below 2 mph (3 km/h).
NOTESTo prevent automatic operation, when the vehicle is stationary, pull out and hold the EPB switch. Within 5 seconds, switch off the vehicle’s electrical system and continue to hold the EPB switch for a further 2 seconds.
If the EPB is operated when the vehicle's speed is less than 2 mph (3 km/h), the vehicle is brought to an abrupt stop. The stop lights do not illuminate.
CAUTIONDriving the vehicle with the EPB applied causes serious damage to the braking system.
When stationary, with the EPB applied and the transmission engaged in a forward or reverse gear, press the accelerator pedal to gradually release the EPB. The vehicle can now be driven away smoothly.
When shifting from P with the EPB applied, the EPB automatically releases to allow a smooth drive away.
NOTESAutomatic EPB release for pulling away from standstill is only possible when the driver’s door is closed, or the driver’s seat belt is buckled.
To override the EPB automatic release, push the EPB switch in and hold.
In an emergency, apply and hold the EPB switch to give a controlled reduction in the vehicle's speed. The vehicle can be brought to a complete stop. The vehicle must be traveling at more than 2 mph (3 km/h), and the accelerator pedal must also be released. The EPB warning lamp flashes, a warning chime sounds, and the instrument panel displays a warning message. The stop lights illuminate. Release the EPB switch, or press the accelerator pedal to, release the EPB.
If an EPB fault is detected, the instrument panel displays a warning message. The amber brake warning lamp also illuminates. See BRAKE (AMBER).
If a fault is detected during EPB operation, the instrument panel displays a warning message. See BRAKE (RED).
To protect against unintentional vehicle movement, the EPB is automatically applied when the driver is detected to be exiting the vehicle. The EPB is applied when Drive (D), Neutral (N), Reverse (R) or Sport (S) is selected and all the following conditions exist:
- With the vehicle’s electrical system switched on, press the brake pedal, and pull the EPB switch out to release the EPB.
- Push the EPB switch in to apply the EPB. The EPB warning lamp illuminates to confirm. See ELECTRIC PARKING BRAKE (EPB) (RED).
NOTESThe red EPB warning lamp continues to illuminate for at least 10 seconds after the vehicle’s electrical system has been switched off.
- The vehicle is stationary.
- The driver's door is opened.
- The brake pedal is released.
- The EPB is applied.
- A forward or reverse gear is selected.
- The driver's seat belt is fastened or the driver's door is closed.*
- The accelerator pedal is pressed.
